Old 04-25-2010, 04:57 PM
portacruise portacruise is offline
Rep: 154 Posts: 626
Originally Posted by localman View Post
Porta - Does that help?! That's an Awesome suggestion!
It makes a lot of sense and would be a heck of a lot simpler.
The link to the inflatable cat is one small boat though. Is that the size you're using or something bigger?
DEPENDS ON WHERE I'M GOING. I CAN PACK THIS SMALL ONE IN AN AIRLINE SUITCASE TO EXPLORE RIVERS WHEN I TRAVEL BY COMMERCIAL AIR OR REMOTE LOCATIONS ACCESSIBLE ONLY BY FOOT PATH. IT ALSO FITS COMPLETELY INSIDE MY HATCHBACK PRIUS WHILE INFLATED.
THERE ARE MUCH BIGGER VERSIONS THAT CAN HANDLE 2 PEOPLE EVEN, BUT THE BIGGER THEY GET, THE HARDER TO PORTAGE....
How big do you think a person could go?
I WEIGH 85KG AND THE WHOLE LOADED UNIT INCLUDING POWER WEIGHS ABOUT 16KG. MAYBE ANOTHER 15 KG MAX LOAD, BUT LESS STABLE.
I wonder if that thai styles long tail weedeater would be enough to propell just a regular old inflatable (a smaller version of the ones they do the white water rafting in).
YES, IF YOU GET THE RIGHT MOTOR/GEAR/PROP COMBINATION- READ THROUGH ALL THE POSTS.
Enough umph you think?
Whitewater boats would probably be OK, but I am partial to pontoons for many advantages. For example you can clear shallow rocks or boulders in between without hanging up on the flexible bottom material-which might rip. Also you can scramble on and off a pontoon instantly or just lower your legs to push or walk or paddle while in different depths of water. All this without marinating your feet in muddy, sandy, pebbly water all day, plus the seats on the pontoons allow a lot more comfort.
Porta
Old 04-25-2010, 05:23 PM
localman localman is offline
Rep: 24 Posts: 12
The thread on weedeater conversions is helpful. Had no idea so many people were doing this.
Weed eater engine conversion
Less surface area as well Porta thanks. Would probably move faster also.
Old 04-25-2010, 05:46 PM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
localman
You ask for the thread I mentioned. It was burried far in the history.
Here's a link
Lurvio
Hopefully creating something useful, since 1983.
Old 04-25-2010, 06:04 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Originally Posted by Jim_Hbar View Post
Here's something to think about.
And floating is entirely optional!
Cool.
Hoyt
Old 04-26-2010, 10:06 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
I know it's been mentioned already, but I'll mention it once more.
Hovercraft
A four stroke with large slow moving propeller may be more quite than most boats able to struggle through the shallows and be far more fuel efficient at it.
If you do have large steps/small waterfalls in the river, going down them should be no problem. Getting back up them may require a winch to a tree or something equally innovative, although I've never heard of anyone having to do that (just made it up).
There are all sorts of videos showing hovercraft climbing small dams in either direction, seek them out if in doubt.
NZ model:
http://www.hoverworks.co.nz/video.htm
USA model:
http://www.sevteckits.com/sevteckits/sevteckits.htm
A thread for reference:
Grey River Trip, New Zealand EasyRideAir Hovercraft Trip
http://www.hoverclubofamerica.org/fo...=1&#entry14362
Cool Pics
http://www.mindspring.com/~lpb3/Chestatee.html
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 04-26-2010, 06:12 PM
Rep: 24 Posts: 12
hmm... tempting, except for the noise. If we wanted to do any hunting I'd be worried we'd have scared all animals within a few miles away.
But as far as a 2 person, durable, backwater hovercraft went (that floated when powered down), is there a concensus on the best kits OR home build plans from scratch?
Old 04-26-2010, 06:32 PM
Rep: 24 Posts: 12
The UH-13P Sportman actually sounds pretty quiet in the video
http://www.hovercraft.com/content/in...index&cPath=47
...tempting!
Old 04-27-2010, 12:35 AM
Rep: 154 Posts: 626
Thanks for posting very interesting info on the track and hover vehicles, they are really cool, unique and allow better access than the best jet boats or even most kayaks.
Most of the river water I like to explore has at least some narrowed sections with moderate to high walls and low overhanging hanging branches which would limit heavy and wide vehicles from passing. Sometimes there are large boulders in the middle of streams that don't leave enough room, so delicate threading or portaging is required. Sometimes only a lengthy footpath in dense forest or brush leads to the water to be explored. Some pools are so isolated they have to be seeded with fish using helicopters. In my haunts, the only options have been to go to something much smaller and lighter to work such inaccessible waters.
The unique vehicles could be used to carry my pontoon to a closer point of access over water though. Probably they would be great solutions for most other amphibian situations.
Porta
Old 04-27-2010, 06:03 AM
hoytedow's Avatar
Resistor
air canoe
Check post#621.
Hoyt
  #25
Old 04-27-2010, 10:44 AM
kach22i's Avatar
Architect
...tempting!
Not sure a video is accurate to a real life experience. Like most things in life you have to get out and see/hear a few different hovercraft at a gathering or rally to form your own opinion.
Most of the noise coming from the typical hovercraft is from the tips of the fan or propeller blades.
However that said on the more "quiet" 4-stroke craft you may hear the engine more than the fan. The noise you hear may be the lawnmower engine, snowmobile or automotive engine being used.
As far as wildlife, they don't seem to know much about hovercraft. Cranes often fly side by side with me. Deer jump about in the water trying to get out of the way as I pass. Fish jump about and hit my craft at times, or is it me hitting them?
I posted a couple of the most quiet craft out there, no ear plugs or headphones required, no goggles required to keep the spray off either (unlike my own craft).
The noisy hovercraft is a two-stroke racer with small fan and with tip speeds near the supersonic.
The quiet hovercraft is a four-stroke cruiser with a large slow moving fan or propeller.
They are two different kinds of birds and there exists a split in between the racers and cruisers which for the world of me I don't understand.
sea-worthy amphibious craft? jkittel Boat Design 108 01-06-2012 11:43 PM
best propolution method, normal Prop, Jet style or paddle wheel? Kalagan Propulsion 20 03-14-2010 03:37 AM
Do they exist? articulating paddle wheel justinDesign Propulsion 27 02-01-2009 08:31 PM
Paddle wheel question dick stave Boat Design 6 10-18-2008 11:22 AM
Anyone have articulation paddle wheel info justinDesign Boat Design 19 10-04-2007 10:52 AM
