Old 01-09-2006, 03:22 AM
fede fede is offline
Rep: 34 Posts: 281
Model Test 2
Hi, this is my second thread on the same topic.
I've finally built a 1:6 (1200 mm) scale model of a racing rib,put on a 7.5 cc outoard,weights centered on the CG (6.5 kg) and tested it.
Results are very satisfatory,the hull is very stable both long. and transv. and it gets on plane very fast with no big hump,also compared to other similar scale models.
Now my question is:
I'm not intereseted about resistence but more about stability,how does scale model trial relate to full size behaviour?
Can I expect the full size RIB to behave same/similar way?
For those who care I have a 2.8 Mb video of the scale model I can e mail.
Old 01-10-2006, 08:39 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Stability will increase when you scale up to full size.
The full size boat will have 6x6x6=216 times the displacement of the model, it will be 6 times as wide, so it will have 1296 times rightening moment :-)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 01-10-2006, 11:15 AM
Rep: 34 Posts: 281
Hi Raggi Thor, thanks for your reply.
Yes, I used the cubic relation for weights the 1:1 scale will weight (hopefully) 1400 kg.
The thing is all other forces (heeling,trimming moments etc) will be scaled too...
Old 01-10-2006, 11:43 AM
Raggi_Thor's Avatar
It's almost allways safe to scale up, the stability scales like L^4 while heeling moment scales more like L^3.
www.MBOATS.no
Old 01-10-2006, 12:15 PM
Rep: 34 Posts: 281
Thanks again,you have been very helpful.
Old 01-17-2006, 01:44 PM
netjaws netjaws is offline
Rep: 22 Posts: 73
I think the question is: are stability characteristics scalable?
Any takers?
Joshua N Straume
Old 01-17-2006, 01:57 PM
Raggi_Thor's Avatar
Yes it is.
www.MBOATS.no
Old 01-17-2006, 03:10 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 512 Posts: 1,032
no, it isn't because the waves and wind characteristics are not scalable
I mean...only static stability and not dynamic stability
Building model...questions on hull design... bduly Boat Design 6 03-29-2006 07:44 PM
SNAME Small Craft Papers CD sorenfdk Boat Design 6 12-29-2005 03:33 PM
can anyone teach me how to model a 3d propeller? dongtao Boat Design 1 11-17-2005 11:30 PM
Scale model trial fede Boat Design 11 11-17-2005 08:06 AM
Test model building ErikG Boat Design 4 05-23-2002 11:21 PM
