Old 02-27-2009, 10:22 AM
yachty4000 yachty4000 is offline
Rep: 36 Posts: 36
I doubt 10mm thick vac mould will be that light.
You could probably get a lighter structure from Balsa or my preference would be to do a hard chine design which I did for my uni project which was lighter than all the high tech boats made of a thin plywood they basically do 2-3mm plywood which is a couple of layer of veneer. With a slightly thicker deck and keel box to stiffen the structure. Try searching the internet for information on the Rythem a Graham Bantock / Marine Modelling one metre that was built this way.
Old 02-27-2009, 01:36 PM
ivor Bittle ivor Bittle is offline
Rep: 135 Posts: 51
RC yacht
You could do worse than to visit my website at www.ivorbittle.co.uk
Ivor Bittle
Old 02-27-2009, 05:37 PM
Tcubed's Avatar
Tcubed Tcubed is offline
Boat Designer
Rep: 303 Posts: 415
Ivor your site looks interesting but it needs updating or something because i can not get in.
T.T.T. a.k.a. T³
Old 02-27-2009, 05:56 PM
FlyingFish FlyingFish is offline
Rep: 10 Posts: 5
Ivor, your website draws interest especially article 2.6. Thanks!
Phil
Old 02-27-2009, 06:26 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Squires500 the thin polycarbonate construction sounds good if you can get the panel stiffness without too much internal structure. I am assuming that you are doing some kind of industrial design course, if so has the uni got a small 3D milling or printing equipment the max size of 500mm makes it perfect for milling hull/s in foam either as the hull or a mold.
Old 02-28-2009, 01:03 AM
Rep: 135 Posts: 51
Uni project
Do the obvious. Use Google and search Ivor Bittle. It works for me. Do not use Firefox.
Old 02-28-2009, 01:23 PM
squires500 squires500 is offline
Rep: 10 Posts: 15
the polycarbonate isnt 10mm thick its more like .1mm thick it is very thin and quite hard although as mentioned it is flexible i believe most of the flex of a hull will be removed when a deck is added too it, i have only seen an example of the hull.
the course im studing is systems engineering at ANU, and we have full access to their machining tools everything from mills a 5 axis cnc flow jet, to spanners and saws. there is a good bet that anything that can be made can be made there. the hull mold they have which you can either use or you can design your own, seems to me to be very wrong in design it has a large bubble shape to the front of the boat and tapers in from there, it seems most conventional yatchs start thin at the front then taper almost to the back of the boat, i beleive this is to give a more laminar flow.
thanks for the site ivor it looks great but im not going to read it at the moment as it is 530am and i just got home from work
Old 03-03-2009, 01:35 AM
Rep: 10 Posts: 15
the group is now faced with a difficult design consideration and that is multi or single hull sailing boat. the benefits as i understand them are that a single hull appears easier to design, will fit nicely into our design constraints, a maximum of 500mm long 300mm wide and 200mm deep for the main hull segments.
however the multihull catamaran has benefits such as being lighter(no keel), and having slimmer hulls and less drag, hence a faster overall boat.
however as we are limited to those constraints i would like to know if 300mm wide is wide enough to create a stable multi hull model.
what are calculations can be used to determine the stability of both boats?
and anything else you think might help.
Old 03-03-2009, 02:29 AM
Rep: 499 Posts: 489
Squires500 I think its about time you started to delve in to the black arts of navel architecture, things like righting moments, GZ and their relationship to heeling moments. Lights boats, be they mono or multi don’t need big rigs to make them go, it’s the power to weight thing. No matter which type you choose the same rules apply, also if you designing a hull to construct, you are doing it once for a mono or doubling it for a multi so the design time is the same. The length/beam on the mono I wouldn’t go below 3:1.
  #25
Old 03-03-2009, 02:34 AM
Rep: 10 Posts: 15
thanks that gives me somewhere to start, i have found that there is a thing called capsize velocity for a multihull boat which tells the maximum wind that the boat can stand before capsizing, i assume i might be able to compare this righting moments
  #26
Old 03-03-2009, 05:58 AM
Rep: 499 Posts: 489
Squires500 due to the small size of the intended model you are going to have a lot of trouble with scaling issues so using rules for full size boat may not be appropriate. Finding the max wind strength for capsize may require real world testing with different rigs for a certain wind range.
  #27
Old 03-03-2009, 06:24 AM
Rep: 36 Posts: 36
I would build a monohull ever time. Having sailed model multihull (mini 40) and raced monohulls mainly one metre.
The dynamic effects are huge the ballast ratio / beams are always so high that transverse stability shouldn't be a problem. One of the key factor in longitudinal stability this drive rig selection in terms of how much sail area you can carry downwind without nose diving and a secondary consideration is tacking. A true conventional multihull will not recover from a nosedive hence the monohull suggestion and will have no oppurtunity for helmsman error in a transverse sense.
The point about using conventional scaling above is very important. RC Yachts are always overpowered if looked at in a conventional way due to wind shear gradients, over scale keel fin arm lengths and scaling effects.
  #28
Old 03-03-2009, 06:34 AM
Doug Lord
Model multihulls under 48" LOA(1.2m) are a disaster in anything but the lightest air. And I love multihulls! Stick with a mono in this size range unless you know the wind won't exceed 5 knots.
  #29
Old 03-03-2009, 02:12 PM
Rep: 135 Posts: 51
Uni yacht
There is a much-sailed design at the length you require in Britain. It is called the Fiesta. It has been very well worked out.
Ivor Bittle
  #30
Old 03-03-2009, 10:28 PM
Rep: 10 Posts: 15
does anyone have the formula for scaled windspeed?
Ballast preference for racing yacht? gbr43926 Sailboats 48 07-13-2011 09:58 AM
Class 40 Offshore Racing yacht Moulds Polarity Boat Molds 0 12-23-2008 06:38 AM
racing model boats pics aztek Boat Design 4 11-28-2008 05:24 AM
Third Year Uni Project laura Boat Design 7 11-21-2003 02:53 AM
my actual uni. project: a 60 footer Gades Open Discussion: All Things Boats & Boating 0 09-02-2002 07:16 AM
