Old 04-12-2005, 08:04 PM
sorandom04 sorandom04 is offline
model boat project, need help
Okay, i have this project I need to do. The requirements are:
1. the boat must fit in a 18 inch cube
2. the boat must be able to sail across an entire pool
3. the boat must be able to support 5 pounds
4. its a race with other boats
5. cannot exceed 50 dollars in the price
Can anyone please provide me with some kinda suggestion as to whether i should use a battery powered motor or how i should go about starting this?
I know this is a forum for real boats, but I thought I'd throw this question out to you guys to see what kinda feedback I can get.
Thanks for the time guys
Old 04-13-2005, 11:45 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
I would suggest a catamaran, 18" long, 18" wide, each hull perhaps 3" beam.
Assuming that the boat is controlled, two decent sized electric motors (one per hull) and two model-boat rudders (one per hull).
If you can vacuum-form the hulls I suggest you do that with a bridge between the hulls. (all electronics except the motors can go in this bridge) remember to put a beam in to make it strong enough though!.
(Oops, I think that may come to more than $50 with the controls)
Good Luck,
Tim B.
Incredible "Secrets of Yacht Design" website located... pkoken Sailboats 579 10-09-2005 08:33 PM
Model Cigarette Boat design dw1905 Boat Design 2 09-04-2005 04:59 PM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
want to build a small model of a boat ronen Boatbuilding 2 12-29-2003 06:35 PM
new boat project rfr Boatbuilding 0 03-06-2003 01:11 PM
