| Model Boat Design I am in the process of making modifications to an existing design and need info on righting moment formula. I need to reduce total weight by at least 2.5 lbs. and can do so by lengthining(sp) the keel.This will shorten the waterline length. sail fast |
| This guy is a model boats designer/builder and he knows his stuff: http://www.boatdesign.net/forums/pro...edschmidt.html You can ask him for info you need. |
| If you're changing length, weight, and keel depth, finding an equivalent righting moment (which changes with heel angle) is much more than applying a formula. I suggest getting a copy of "Principles of Yacht Design" and read the chapters on hydrostatics and stability. You're going to need to do some research. |
Is that on a 36/600? That will be hard to do-especially if yours is already one of the light boats at around 5-6lb! I'd suggest a new design with the max wl length and narrowest hull possible. I don't remember: is movable ballast still illegal? Thats one solution but it would make a boat that would require more channels and lots of practice to sail well-but it would be a rocket. Again, in the old days(10 years ago) light boats were around 5-6lbs with an 80% B/D ratio-4-to 4.8lbs of ballast. Losing 2.5lbs from a boat like that will be tough-and likely impossible without either a wildly deep keel or movable ballast. We can guesstimate how deep the keel has to be for a skinny 36-to lose that much weight and have the same RM would probably require an 18" keel going to 36". If I were you I'd contact Lester Gilbert or Graham Bantock and see if their research has revealed negatives other than the obvious ones for that kind of keel length on a 36" hull. Both those guys were helpful to me in the old days. Good Luck!
| Model boat DESIGN The boat I need to loose weight on is a Pointing 36 by Amen, it is a 9.5 lb boat and looks like a Mistral by Bob DeBow. The Keel is a good 6" shorter than my CF TalonII which is less than 5lbs. Sail Fast |
| Model Boats Quote:
sail fast |
| A model boat design | guitarhero | Boat Design | 1 | 03-09-2009 11:55 AM |
| Design project - model tow test | Brands01 | Powerboats | 6 | 01-10-2007 03:48 PM |
| Building model...questions on hull design... | bduly | Boat Design | 6 | 03-29-2006 07:44 PM |
| Make model design | thinwater | Sailboats | 0 | 10-30-2005 12:48 PM |
| Model Cigarette Boat design | dw1905 | Boat Design | 2 | 09-04-2005 03:59 PM |
