Old 04-30-2010, 01:52 AM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Minimising banking in a turn
What design elements help to minimise banking in a low to medium speed planing powerboat?
Old 04-30-2010, 06:32 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
Full length, horizontal chine spray rails.
Old 04-30-2010, 07:51 AM
mark775
lower rudder aspect?
Old 04-30-2010, 10:46 AM
Rep: 749 Posts: 1,314
More beam, harder chines. Beware of a planing boat that remains flat when turning. Skidding and perhaps tripping is not good for ones health.
Old 04-30-2010, 10:54 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
Lower CG.
Also w very soft chines the inbd chine will pull the inbd side down and cause excessive banking in sharp turns. I had a Mukilteo Boat (a long and narrow OB boat w canoe like bottom aft and very soft chines (softer than most canoes)) and while making sharp turns it felt like I was going to get thrown out of the boat. This boat lacked strakes aft and close to the WL.
Incidentally the "Muk" boat had (basically) an Axe bow.
Easy Rider
Old 04-30-2010, 11:39 AM
u4ea32's Avatar
u4ea32 u4ea32 is offline
Rep: 175 Posts: 378
Chines and strakes have nothing to do with how much a boat banks in a turn. The reason a boat banks in a turn is due to the sum of dynamic forces during the turn. Obviously!
Several things affect this.
1) Height of the CG above (or below!) the other force vectors. CG will have an outward horizontal force vector (centripetal force). However, on most normal powerboats, this is actually minimal, because the CG is usually pretty low. Those hideous gin palaces with very high superstructures, and vessels like container ships, a very high CG results in an outward lean instead of an inward bank.
2) Vectored thrust below the other forces (outdrive, pods, outboard). This is often a major effect, because the thrust to push the boat is as much as all other forces acting on the boat.
3) Rudder depth: usually not a factor with powerboats, but a big factor with modern sailboats.
4) Perhaps surprisingly, Deadrise: there can be a huge rolling force due to water pressure being much higher on the outside of the turn compared to the inside of the turn. The deeper the V, the steeper the bank. The bow contributes to this too, so boats with lots of deadrise forward for a smoother ride exhibit more roll than otherwise one might expect.
But chines and strakes have essentially zero effect, as the roll axis force from pressure differentials very close together (opposite sides of a given chine or strake) is very, very small. Its all about the lever arm, and strakes and chines have none locally.
Broad beam -- or really, lots of stability -- of course reduces banking simply because so much more force is required to cause a roll.
The thing that causes the rolling force in hulls is the flow of water diagonally across the bottom.
--> A soft chine can, as Easy mentioned, allow this diagonal flow to remain attached, and therefore resulting in a large downward force on the inside of the turn -- lots of lift downward, just like putting the flaps down on an airplane wing causes a lot of lift upwards.
--> Deadrise causes high pressure on the outside, low pressure on the inside, so a big rolling force.
--> a keel causes lots of drag to this diagonal flow, and so results in an anti-roll force: the high pressure side is now pushing laterally on the keel, instead of only upward on the bottom.
I might be a rocket scientist, but this isn't rocket science. You just need to think about the flow going diagonally across the bottom during a turn.
David Smyth
Old 04-30-2010, 01:52 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Well said David. There are a lot of different things that can cause heeling one way or the other in a turn. A round bottom boat will often heel outward due to suction created on the outside turn in the bilge. Direction of the heel will depend on which force dominates at the start of the turn. A V hull will almost always heel into the turn and gets worse with more V as David said. A dory can heel inward an alarming amount as the entire bottom acts like the outside of a V in creating pressure and the inside flare does nothing to limit the heel.
not a rocket scientist but used to track Redstones in the Bahamas.
Tom Lathrop
Old 04-30-2010, 04:16 PM
Rep: 109 Posts: 242
Thanks Gentlemen.....
So, a low deadrise, relatively beamy hull is a good place to start....(from tha point of view, at least)
Old 04-30-2010, 04:36 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Banking in the turn keeps the dishes from sliding off the table.
Hoyt
Old 04-30-2010, 04:42 PM
mark775
Might you think you would be less of an ******* to say something like, "IMO, Chines have less to do with how much a boat banks in a turn than the sum of dynamic forces during the turn" than the original "Chines and strakes have nothing to do with how much a boat banks in a turn. The reason a boat banks in a turn is due to the sum of dynamic forces during the turn" Obviously! Why does every thread have to have someone like you beating on his chest?
Old 04-30-2010, 05:05 PM
Easy Rider's Avatar
Rep: 694 Posts: 670
When a boat turns the stern moves outboard and so the water can be easily moving at 45 degrees to the inboard chine. The water is moving outboard as fast as it's moving aft. Water tends to follow a curved surface and has considerable mass so as the water is pulled up at the inboard chine the lee rail of the boat is pulled down and the outboard side of the boat is acting like a lateral plow causing the outboard side of the boat to rise ..big time ..as the kids say. Try those dynamic forces on for size .. and if you find something wrong w my theory ..show me. Otherwise don't call me an idiot ..again.
Easy Rider
Old 04-30-2010, 05:56 PM
mark775
You are more diplomatic than I, Easy. What you say makes sense to me.
Old 04-30-2010, 07:33 PM
Easy Rider's Avatar
Rep: 694 Posts: 670
Thanks .. I'm learning .. from my mistakes the other day.
Easy
Old 05-03-2010, 10:51 AM
u4ea32's Avatar
Rep: 175 Posts: 378
Yes, you are correct. Sorry about that tone.
David Smyth
Old 05-03-2010, 12:12 PM
Rep: 1493 Posts: 7,447
Banking on turns is one characteristic of well behaved boats. Why minimize it?
why does my yacht turn to port? panache Boat Design 10 11-11-2009 03:05 AM
Turn 2D Catamaran into 3D Spiv Software 11 06-01-2009 11:24 AM
The Turn Over! ucb4ume Wooden Boat Building and Restoration 43 12-16-2008 09:22 PM
Engine Wont Turn. LMannyR Sterndrives 1 07-25-2007 08:37 PM
Best way to suspend and turn a boat mtnrat Boat Design 9 09-08-2006 03:00 PM
