Old 06-08-2010, 06:33 PM
Andrewc42 Andrewc42 is offline
Rep: 10 Posts: 5
Mini Transat help
Hi,
I'm currently designing a Mini Transat which is going ok. Does anyone have any hull information or drawings they could spare me? As this would be a great help
Cheers,
Andrew
Old 06-14-2010, 03:48 PM
luckystrike's Avatar
luckystrike luckystrike is offline
Power Kraut
Rep: 71 Posts: 143
Originally Posted by Andrewc42 View Post
Hi,
Hi, do you mean as a reference help for your design? Detailed drawings of competitive designs will not be available because they are secret. But you can learn a lot from photos or discriptions. To get some informations you should surf the net intensively and save all the informations you can get. What Do you want to learn about mini design? Hull lines? Balances? Structures? Class Rules?
Grrreetings from the North Sea Coast, Michel
Old 06-16-2010, 12:00 AM
Rep: 10 Posts: 5
Hi,
I have looked at many Mini Transat website and they have been helpful... What I would really like to know is: What is the ideal Prismatic Coefficient for a Mini?
I am modeling a mini up on Maxsurf at the moment, and it going well.
cheers
Old 06-16-2010, 05:24 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
0.58
(just kidding ... )
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 06-16-2010, 09:27 AM
Power Kraut
Rep: 71 Posts: 143
Hi,
cheers
I think in a boat half as wide as long the pc is not important anymore.
Most mini's are drawn by following the "dynamic flow method". That means a mini is big windsurfboard with a round bottom to have a planing area up to 10° or 15° heeling (and then comes the chine).
To face light weather and upwind sailing in displacement mode the mini's rely on a enormous sail area and stability (canting keel, waterballast), not on good underwater lines.
Greetings from the North Sea Coast, Michel
Old 06-16-2010, 07:52 PM
Rep: 10 Posts: 5
Thanks for that.
Where would I be able to find information on the Dynamic flow method?
Cheers, Andrew
Old 06-17-2010, 01:58 AM
Raggi_Thor's Avatar
Google...
And you'll find a lot of tips.
For example, http://www.vgyd.com/Mini.html
The all carbon fiber hull and deck incorporates the latest proven trends in hydrodynamics for this ilk of offshore racing boat. The canoe body has a fine entrance angle in its forward sections, and a gentle rocker fairing into a defined wide-body chine aft. This optimized configuration will give the boat a significant advantage in terms of raw power and its ability to perform well in a broad range of conditions.
The appendages consist of a 80o articulating fin and bulb, a centerline dagger board, and twin kick-up rudders. The versatility of this arrangement, plus the added water ballast, dramatically adds to the sailing stability and performance of the boat. The keel has a steel fin supporting a lead bulb. The dagger board and rudders are all carbon construction.
www.MBOATS.no
Mini Cat Transat? Alex.A Multihulls 42 03-16-2010 02:26 AM
Mini-transat circumnavigation GTO Open Discussion: All Things Boats & Boating 23 02-18-2010 04:53 PM
Mini Transat Foils - canards fng Sailboats 13 10-17-2009 07:36 PM
Rudder foils for Mini Transat Polarity Boat Design 4 03-07-2006 08:53 AM
Photos of Mini Transat under construction Zaynab Boatbuilding 0 11-03-2003 05:07 AM
