#121
| The reason I was thinking axial fans are better than centrifugal fans for amphibious hovercraft (when considering heave acceleration) is that someone once told me axial fans have a flatter HQ curve. Some info here (non-hovercraft): http://ateam.lbl.gov/Design-Guide/DGHtm/fans.htm Example (non-hovercaft): http://ateam.lbl.gov/Design-Guide/DG....axialfans.htm ![]() Centrifugal vs. vane-axial fans Quote:
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
#122
#123
What am I missing here?
#124
| Mixed flow designs (witness turbochargers) are used to create higher delta-P across the 'machine' than can typically be achieved by purely radial centrifugal fans. That is a gross simplification that ignores so many other design factors...but one factor that seriously mitigates against using mixed flow whels is their complexity of construction. Airfoil centrifugal wheels are SO much easier to build. |
#125
I'm building a scale hovercraft model, looking to use about a three inch diameter. Has CNC machining rewritten the rule book on what can be made and scaled up?
#126
I'm partial to the FC fans for full-scale application as stern seal inflation boost fans. Great pressure rise and flow in a compact min-diameter package..not so great in efficiency but that gets lost in the 'noise' when you consider they average only about 15-20 HP each. As far as I know..all the mixed flow wheels are/were cast... |
#127
FOR SALE: "Own a Piece of History. This is a rare opportunity to be the only person in the world privileged to experience the speed, adventure and prestige of owning Gentry Eagle." http://www.gentryeagle.com/ Quote:
The SES you are working on is over one thousand feet long? 57 x 20 = 1,140 feet long................or is the model about three feet long? 57 x 12 divided by 20 = 34.2" long? What good is 1/20th scale? I thought it had to be at least 1/6 scale to be of any use.
#128
Gentry and his team never got to finish the SES..the project collapsed when he went in to teh coma and never recovered. |
#129
Maybe my math is wrong; let's say a total lift of 10 HP assuming a useable 7.5 HP of lift, right? (1.5 x 5 = 7.5) I think 20 foot long hovercraft (not an SES) uses at least 20 HP for lift. Example: http://www.hovercraft.com/content/in...ex&cPath=35_55 Therefore, a 60 foot long hovercraft might be using 60 HP (I'll check an old Jane's Surface Skimmer's - 1976 or 1987, later). The SES uses 1/6 the lift which a fully amphibious hovercraft uses? I could believe 1/2 the power requirement, but 1/6? Is this more of a air assisted cat?
#130
| Found this..........................no good pictures though. http://www.globalsecurity.org/milita...s/ship/hss.htm Quote:
#131
#132
Your competition....................? SES pictures...................models too. Blyth Bridges Marine Consultants Limited http://www.blythbridges.co.uk/projects_column.html ![]()
#133
| ah yes..my old friends Andy Blyth and David Bridges. Been quite some years since we worked together on some of those SES concepts. Our competition for..what? |
#134
| Model testing? Solving ride, stability and buoyancy issues for surface craft of unconventional design? I thought there was some overlap of services, my mistake? FYI: Right now I'm building a five foot long hovercraft model. It started out as a mock-up study for the cabin area only, and just to see if it would work as intended. I enjoy taking plan and section sketches beyond the 2D and into model form, real models (3D) not computer models. I kind of got carried away and now there is no turning back. I just picked up three (3") mixed flow fans from a vacuum cleaner repair shop ($15). I also picked up two (4") axial fans for thrust ($10) from an appliance repair shop. I have the electric motors and NICAD batteries from a few years ago and now have to make it all come together somehow. ![]()
#135
No mistake on your part..I just didn't know who or what you were referring to as far as competition. We have competitors..but few and we compete in a very small market. Collaboration is as often the case as direct competition.. Our biggest source of work is supporting the 'big boys'..US and foreign navies and larger design houses and shipyards that don't have the expertise in-house to design and build the 'weird ones'..SES, ACV, SWATH, hydrofoils, cats, and hybrids thereof. Stabilization, or 'ride control' used to be our main specialty and primary business, but that morphed in to 'whole ship' design over the last 20+ years and now the ride control systems are a secondary part of our business today..even though we are one of only a handfull of companies worldwide that produce such systems. |
| Help Identifying military 36 foot inverted V hull | Argonaut | Powerboats | 19 | 06-07-2011 09:43 AM |
| Fuel Bladder (Military Issued) | jas4906 | Marketplace | 1 | 03-04-2006 11:22 AM |
| 37' Molds For Sale Uscg Certified/military | Premium | Boat Molds | 1 | 07-17-2005 12:29 AM |
| military catamaran | phil knell | Boat Design | 1 | 08-15-2004 04:43 PM |
| MACC 2004 - Military fast craft conference | CDBarry | Powerboats | 0 | 04-21-2004 07:15 AM |
