Old 12-10-2007, 09:56 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Does salt water like to eat the spongy foams?
Salt water is so rough on everything else, I'd just assume.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 01-14-2008, 01:41 AM
nero nero is offline
Rep: 112 Posts: 624
too complicated?
Finally, making the time to work on build plans. The below pict is how I intend to build the nose crash blocks. The center is a stack of extruded polysteren. This is the 100 psi (cheapest) pink or blue insulation foam that is found at the local building supply. On the outside of this is 12 mm of CoreCell (SANS foam). The forms below it are to heat form the CoreCell. While the CoreCell skin is still in the forms, the main block will be fitted and bonded into it.
The layer block below the dwl is of CoreCell.
The blue and yellow sweeps are the area I intend to use memory foam.
Minicell is the memory foam product intended. Claims to be impervious to rot, mildew, mold. It comes in 4 inch thick slabs. Can't test samples since I am currently in France.
Reverse Bows quicksail Boat Design 35 12-10-2008 06:23 PM
Reverese bows SC1 Boat Design 26 06-01-2006 08:36 AM
sailboat bows dman Sailboats 109 11-06-2005 08:54 AM
Searching the Memory Banks kudu Boat Design 3 07-30-2003 11:03 AM
Using multiple bulbous bows as blocks? 8knots Software 3 04-22-2003 06:27 AM
