| ???measuring??? As some of you know I'm building a norwegian pram. In "10 Wooden Boats you can build" from WoodenBoat it says, "... shape the garboards by tracing one edge from the bottom board, then lift a few measurements from the drawing and use the batten and axe again." What i understand from this is that the bottom board is shaped and then you the plank that's intended to be a garboard and trace the top(?) edge of it and cut/bevel it. This will be a Holmsbupram so the gar boards will be flat on top of the bottom board. Right? |
| Measuring bulb volume | mojounwin | Stability | 2 | 05-25-2010 05:19 PM |
| Measuring distortion | DGreenwood | Boat Design | 0 | 12-29-2009 06:22 PM |
| measuring outboard prop hp? | kenfyoozed | Boat Design | 4 | 03-18-2005 05:00 PM |
| Measuring odd shapes, | duluthboats | Press Releases | 2 | 08-11-2004 03:45 PM |
| Measuring a hull | duluthboats | Open Discussion: All Things Boats & Boating | 6 | 11-07-2002 01:42 AM |
