Old 02-21-2009, 05:53 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
McNaughtons Scantlings - fibreglass weight sheathed strip construction
Hi all
Just working my way through the Mc's scantling rules I bought recently (they are cheaper to buy as PDF instead of books - great idea !)
I would love to get verification that I inderstand the formulae.
Their scantlings for 'glass weight over strips planking are expressed like this
"If ordinary balanced weave glass cloth is used, the total glass cloth weight of each skin in ounces per square yard, equals 3.67 multiplied times the cube root."
So, if the boat is evaluated to a cube root of 3.8 (3500 lbs displacement),
or
3.67 x 3.8 = 13.9
or 13.9 ounces of glass per square yard on each side
This sounds reasonable, but have I worked it out correctly do you think ?
Any and all thoughts welcomed.
Old 02-21-2009, 06:48 PM
apex1
Originally Posted by rwatson View Post
Hi all
Hello rwatson,
have no idea if that works well, but I fear it does calculate the glass only?
Real figures are provided here:
http://www.r-g.de/en/
change language, goto onlineshop, select your product and find laminate weight per m² incl. resin, for every single sort of fiber, weave etc.
a program to calculate laminates: (must register)
http://www.r-g.de/laminatberechnung_registrierung.html
and this is a REAL test:
http://download.r-g.de/rg_dokumentation_whz.pdf
unfortunately (for you) in German only.
I hope I could help a bit further!
Regards
Richard
Old 02-21-2009, 10:22 PM
Alik's Avatar
Alik Alik is online now
Rep: 1020 Posts: 1,895
I wonder why use these amateur 'scantling rules' if official standards (ISO12215-5, ISO12215-5 simplified, GL, etc.) are available?
Old 02-22-2009, 01:39 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Maybe a fear of VOR's and Vendee boats having ISO scantlings
Reckon however they aren't
Old 02-22-2009, 01:48 AM
diwebb diwebb is offline
Rep: 65 Posts: 120
have a look at Dave Gerr's book The Elements of Boat Strength for builders, designers, and owners. This book synthesizes the formulas and scantling rules in to simple tables and graphs for those who do not wish to spend a long time and a lot of effort to get a viable construction layup for their boat. I find it very useful and relatively easy to understand. Also difficult for a non professional to make an eror in selecting a suitable weight and thickness for the hull and other parts of a boat.
Old 02-22-2009, 02:01 AM
Alik's Avatar
Provided that there is no error in the book
Actually, the method in that book does not work for planning boats.
Old 02-22-2009, 03:40 AM
Rep: 2891 Posts: 8,798
Dave Geer's "scantling rules" work rather well, including planning hulls. What they don't do is produce the lightest boat you can get away with, which is an intentional side effect of his rules. He clearly states the rules are designed for well founded hulls, not light weight machines. This covers the vast majority of desires when looking for this type of information. He also points out that the rules can be shaved to a degree without harm, but understandably rejects any ill will, that may come about by someone looking for this type of short cut. If you need this type of hull, then the reasonable designer works out the loads and scales everything accordingly.
Old 02-22-2009, 06:10 AM
Alik's Avatar
They don't really have planning hulls in Gerr's book as they do not define planning speed. Gerr uses increment of thickness for over 10kts(?), and this sounds rather strange because there is no dependence from Froude number. And actually there is no definition of design loads...
I mean Gerr's books are always great reading - I study his "Mechanical systems" right now, that is excellent. But for structural calculations there are better professional sources supported by software. I still believe for amateur designers simplified method presented in ISO12215-5 is the best.
This is my calculator for planning boats, based on ISO simplified method, works for craft under 12m.
Old 02-23-2009, 01:26 AM
rwatson's Avatar
So many answers .... but no solution to the question. I dont know why people assume I have no other source of calculations than McNaughtons.
Also, funny how close McNaughtons comes to the calcs on the 'easy ISO calculator' since they are 'amateurs' !!!
Still, if anyone wants to throw in a comparative figures, feel free
Length 8.5 metres
Beam 2.24 metres
Lightest displacement 1200 kilos
Heaviest Displacement - 1800 kilos
Draft around .3 metres
Freeboard - around 1 mtr
Power Source - 50 -up to 70 hp outboard
Top speed around 20 knots with lighter load
Building materials - Ply ,or epoxy over strip planking
Old 12-17-2009, 06:18 AM
ricardoribeiro's Avatar
ricardoribeiro ricardoribeiro is offline
Junior member
Rep: 29 Posts: 43
Você tem o easy structural calculator xls planilha para sailboats?
Fibreglass boat construction method amamini Fiberglass and Composite Boat Building 5 08-01-2008 06:29 PM
Multihull hull construction - scantlings student Multihulls 1 06-17-2006 12:17 AM
Gel coat/Epoxy fibreglass cloth construction mikeboatman Fiberglass and Composite Boat Building 2 04-29-2006 02:06 AM
Sheathed strip - Limits? Mohan Pakkurti Wooden Boat Building and Restoration 1 01-24-2005 11:01 AM
Plate thicknessand other scantlings for aluminium construction Willallison Boat Design 14 05-20-2004 09:11 AM
