Old 08-27-2007, 07:10 PM
Jratte Jratte is offline
Rep: 10 Posts: 34
Mayline straight edge installaion.
I just received a 60" Mayline straight edge for my drafting table. I've got the hardware but there weren't any installation instructions included. Anyone care to tell me how to install. TIA.
"...(the) ill-fated boat...burned, sank, and, after being retrieved, exploded and killed one of the men who had built her."
Old 08-28-2007, 02:40 PM
Rep: 749 Posts: 1,314
Gadzooks Jratte! I thought that parallel straight edges went out with buggy whips. Actually I still have one on my board. To hell with those infernal computer thingys.
Heres how. The string or cable is anchored at the top or bottom of the board. There will be two anchoring posts with a knurled nut to adjust the string tension as well as the parallelism of the straight edge stick. Let us say that you will attach those posts to the bottom of the board, the part nearest your belly button. Start at on end of the string...say it is anchored at the lower right corner of the board. The string is going to cross itself inside the straight edge, Run the string up from the first anchor position to the top of the Lower right pulley in the stick, continue to the bottom of the upper left pulley, around that pulley to the upper right, then back diagonally to the lower left and out of the stick. Fasten the remaining end of the string to the lower right end of the board and adjust as necessary.
This is sort of a puzzle, but easy when you do it one time. I do use an infernal computer but my antiquated straight edge, triangles, splines, and ducks like me better.
Old 08-28-2007, 04:35 PM
Rep: 10 Posts: 34
[quote=messabout;158589]Gadzooks Jratte! I thought that parallel straight edges went out with buggy whips. Actually I still have one on my board. To hell with those infernal computer thingys.
Yes well they kinda did. But I decided to go back to school and now I get to hand draft all over again for a bit. Thanks for the help, I'm sure if I re-read your description a few more times it will make more sense. The cable is already run through the parallel i just need to know what to anchor where. I think.
First boat w/straight shaft & rudder Jackpacc Inboards 5 07-17-2007 03:42 PM
Shooting straight gelcoat witha 2.5mm tip? searaytuna Fiberglass and Composite Boat Building 8 04-15-2006 06:20 PM
80-100' straight trees for masts Paula Lucas Wooden Boat Building and Restoration 1 02-19-2006 08:53 PM
Straight Thru-Hull Fitting 1-1/2'' accent33 Propulsion 3 05-31-2005 12:53 PM
fastest straight line sprinter lucdekeyser Boat Design 1 10-02-2004 06:05 PM
