| Maximum beam and COB I'm getting ready to design a variant of the Raptor for a friend. Mine is 17' 3" by 26" and he wants one a bit longer with about the same beam, but more legroom. The idea I'm playing with is trying to separate the center of buoyancy from the point of maximum beam by about 2 or so feet so that when he's sitting in the cockpit his knees are at the widest point of the boat. Is there any reason this can't, or shouldn't be done?
__________________ Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR |
| For the most efficient paddle stroke you need to plant the paddle as close as possible to the center of the boat so it may not be the most efficient. It all depends on priorities. |
| You can pull this off by fattening or thinning the sections at one or the other end of the boat. That ploy would change the curve of areas to a different shape which may or may not be optimum. This would let you move the CB to suit the situation There are some designers who claim that a long skinny boat needs a couple of sections, at the middle of the boat, to be identical which would tend to make the sides parallel. In this case you have not manipulated the CB but have merely provided knee space aft of the CB |
| There is no problem doing this, as long as you match the CB with the CG. Almost every shape conceivable has been used in kayak hulls, small changes result in small changes (or not detectible) changes in how it behaves. I think your kayaks are a bit wide for my taste, anything over 22" is wide to me. Realize too that making longer will also increase the righting moment (it displaces more water as it rolls over). |
I haven't drawn anything up yet, but I'm thinking that something like a pointy teardrop shape with the maximum beam shifted slightly forward might work. I'll have to draw it up in Freeship and see how the hydrostatics look.
| Here's what I've come up with so far... Dimensions are 18' 6" x 26" with a design draft of 6" at a displacement of 300 lbs. This design, named the Black Crowe for the friend I developed it for, is a little slimmer hull on a little longer boat, but the resistance numbers from KAPER look almost the same as the Raptor.
| Solar Maximum | JonathanCole | Boat Design | 40 | 05-11-2012 05:14 PM |
| Maximum Capacity Calculations | Willallison | Class Societies | 11 | 06-22-2010 04:55 PM |
| Catamaran beam vs trimaran beam | seadog1970 | Multihulls | 11 | 08-19-2007 05:49 AM |
| What is the maximum deadrise angle? | jfblouin | Boat Design | 3 | 09-20-2004 07:36 AM |
| Maximum beam ? | Slowmo | Sailboats | 48 | 09-01-2004 01:03 PM |
