Old 12-05-2005, 01:22 PM
Patrick_76 Patrick_76 is offline
Rep: 10 Posts: 5
Maximizing small boat stability
I am trying to maximize the stability of a small boat that I am designing. It is 12 feet long with a bottom width of approximately 40 inches. The boat does have a slight v for most of the boat (chines are 3 inches above the keel). The beam is 60 inches. Side height right now is 15 inches. The hull lines are somewhat similar to Devlin's Bluebill. I am designing this boat for use in sheltered sloughs, creeks, flooded timber, and small, slow moving rivers (no more than 150 feet across). Any thoughts are how stable such a design will be?
Thanks,
Patrick
Old 12-05-2005, 02:39 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
It sounds reasonable. A deadrise of 3 to 20?
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 12-05-2005, 03:18 PM
Rep: 10 Posts: 5
I think I'm going to bring the V up some 10-12 inches at the front. I'll post up a pic when I get home to give you a better idea.
On the deadrise, do you think that is too much or not enough for a small boat? The thing will probably be powered by a 5 or 9.9 hp motor.
Old 12-06-2005, 07:33 PM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,647
The bottom sounds ok but the flare on the sides seems excessive at almost 34 degrees. 40" chine beam and 60" sheer beam?
Tom Lathrop
Old 12-07-2005, 02:30 AM
Raggi_Thor's Avatar
Maybe the topsides has more flare than usual, but if you are rowing you want a small waterline beam. The displacement up to the chines may be around 60kg or 130lbs?
www.MBOATS.no
Old 12-07-2005, 10:37 AM
Rep: 10 Posts: 5
That beam is a bit wide isn't it? The original plans had a 48" bottom (1 sheet of plywood wide). I dropped the width at the chines, but didn't drop the width at the beam. I'll check some different sizes tonight to see what comes out looking better.
Thanks,
Patrick
Old 12-07-2005, 10:50 AM
Raggi_Thor's Avatar
If the boat is very light and someone step on the rail....
www.MBOATS.no
Customizing a Jon Boat Jepley Boat Design 4 11-04-2005 08:17 AM
Boat Stability help pls. trouty Boat Design 11 10-28-2005 11:55 PM
building polyethilene boat gesdim Fiberglass and Composite Boat Building 0 01-09-2005 09:50 AM
small drift boat for fishing/whitewater angel Wooden Boat Building and Restoration 2 07-02-2004 12:52 AM
