| Max Area Formula? Hi Here's the problem. If you have a piece of steel flat bar or whatever of say 1000mm in length, how do one determine what shape will give max area. For example; if made in a square of 250mm x 250mm = 0.0625 m sq. or reqtangular of 300mm x 200mm = 0.0600 m sq or reqtangular of 350mm x 150mm = 0.0525 m sq or diameter or 318 mm = 0.0794 m sq Seems a circle work out the largest or am I mistaken?
| Wynand, if you mean wrap the bar around the area so the bar is the perimeter, then yes, the circle has the largest area. |
| Pull a very thin wire and cover the surface of your liking. That will be a big surface! That's how Carthago was built. |
| bigger props faster ship? | Peter H | Boatbuilding | 23 | 02-01-2010 12:08 PM |
| Wetted surface area - approximate formulas | Mike D | Boat Design | 11 | 08-25-2005 11:00 AM |
| Curve of area...Stu | Turner | Boat Design | 0 | 03-29-2005 02:08 PM |
| Building a heat exchanger into the hull | djackson99 | Powerboats | 42 | 03-21-2005 02:15 PM |
| Wetted surface area II: Cat hulls or Monos? | Mike D | Boat Design | 1 | 09-25-2002 11:26 PM |
