| Now, Gonzo, that's just stirring the pot! ![]() |
| gonzo says: "Where do semi-displacement boats fit in?" They're just a little bit slower than semi-planing boats ;-P |
| Now you people are just causing trouble Hey I do recall some semi displacement craft doing much higher speeds than most planing hulls. And what about subs? For a displacement craft they can go pretty quick. Anybody like to try and summarise this in one sentence? It hurts my head... |
| [quote]Originally posted by BrettM [b]Tom, Hull speed is the generally accepted upper end limit of a displacment craft beyond which the power requirements become excessive. (Not to say it cannot be done without effort) Planing craft exceed this limit going over the hump and into pre planing regeime and then to full planing. Why not start here? Hence I defined this point. >>>>Brett, you can certainly do that but it makes no difference how you define planing. Firstly, many will not agree and secondly, no such definition will make any difference to the boat. I can find boats that will not act like the "definition" says they should. Such definitions are only applicable when the discussion is limited to a narrow range of hulls. Hull speed works ok for slow, heavy boats of similar fat length/beam ratios but don't work well with very light boats or high length/beam ratios.<<<< As far as planing mathematics is concerned, a flat plate is the simplest and most basic concept available however far derived it might be from a real world boating application. Hence my suggestion as a starting point to the original poster who is looking for a mathematical description and not a design solution. There are plenty of ways to go from there. >>>>>I agree that a flat plate is both the most simple and the most appropriate place to start an explanation of planing. If you ignore the whole concept of hull speed, planing becomes much easier to understand. After that is clear, then a look at the problems of the transition speed range is much easier. One thing to keep in mind is that the sum of buoyancy and dynamic (planing) lift must always exactly equal the displacement of the boat. I did not say equal the weight of the boat since there is often some negative dynamic lift, especially in semi-displacement (semi-planing or whatever) hulls. In full displacement hulls, negative dynamic lift is greater than any positive dynamic lift, which is why they will sink if towed too fast.<<<<< Tom Lathrop |
| Brett, You say that subs are pretty quick for displacement boats, and could we sum it up in one sentence. Well, I gits two words for ya :- "Nuclear Reactor" ;-)) Steve - anything can be fast with enough power. |
| Submarines & Entering wedges No, deeply submerged objects do not have wave drag. They do have more wetted surface, but at some speed this crosses and deeply submerged objects are more efficient. Note that in nature we have submarines, (fish, etc.) fully immersed in a fluid, and birds, also fully immersed in a fluid, but no creatures that operate in the interface when they want to travel efficiently. Operating in the interface is costly in terms of energy given limited length and high speed. Also, again, the easiest way to mathematically model planing is entering wedge approaches, and some of the most recent work is able to accurately derive both resistance and motions from basic physics. Journal of Ship Research had a very good paper a year or so ago, and Dick Akers has presented several papers and presentations through SNAME, MACC, HPYS, Workboat Show and IBEX. The idea is to look at the hull from the point of view of a fixed particle of water. Then the hull looks like a series of wedges being driven downwards into the water, which we can solve from first principles. |
| The problem of wave resistance is because the boundary between air and water is not rigid. Eddies and waves create a huge resistance. In a completely submerged object eddies are much smaller and there are no waves.
__________________ Gonzo |
| Steve, Picture Tim Allen fixing a nuclear reactor to his tinny in the garage and grunting "more power"... Perhaps a sold fuel rocket might work hmmmm...Guest, I am guessing that the first princples approach to each element in the strip method you mention is almost similar to the simple flat panel? Tom, many don't understand where the 1.34sqrt(L) eqn comes from. Hence I mentioned it. This forum is way too small to make a full discussion of it. Not to say I understand everything about it any way. Brett |
| I originally posted this to rec.boats.building, but it serves well.... Here's a quote from a reputable source (which I won't name since they may not like it) that explains it - sort of. "THe energy associated with the transverse wave system travels at the "group velocity" of the waves, which equals one-half of the phase velocity in deep water. The propulsion system of the ship must therefore put additional energy into the wave syste, to replace that which "falls behind". A nominal relationship between ship speed and the length of the corresponding transverse wave may be found by equating the ship velocity with the _celerity_ (phase velocity) of a small-amplitude gravity wave in deep water, Vship = Cwave = sqrt( g.Lw/(2.pi)) = 2.26 sqrt(Lw) where Cwave = celerity or phase velocity of the wave in ft/sec and Lw = length of the transverse wave in feet. This can be converted into speeds in knots: Vs = 1.34.sqrt(Lw) (sorry, no workings shown - trust me) William Froude first pointed out the practical limiting speed for surface-displacement ships whe he observed that "the speed with which wave resistance is accumulating mosr rapidly, is the speed of an ocean wave the length of which, from crest to crest, is about that of the ship from end to end" (Froude 1955 p.280) This condition is found by substituting the length of the ship for the length of the wave, giving a relationship commonly referred to as the _hull speed_, or critical speed-length ratio: Vs/sqrt(Ls) = 1.34 <end quote> And there you have it. Steve |
#25
| I think my comment opened a can of worms I can go fishing with for a couple of years . Hull speed in knots defined as 1.25 to 1.3 times the square root of the waterline works for boats of moderate design. Barges have a much lower hull speed. Hulls with beam/length ratios of 10 or more can have hull speeds twice that. And opening another can: how about bow bulbs. How do they affect hull speed?
#26
| Gonzo saith: "And opening another can: how about bow bulbs. How do they affect hull speed?" ou're on your own, there, gonzo. I've done my bit, and my brain hurts. Next! |
#27
| Not as mathematically complex as much of the dicussion so far, but maybe relevant. My Westlawn text describes planing as - As far as we are concerned a high speed powerboat is one that is capable of exceeding a speed / length ratio of 3.5 where: speed / length = V (knots) / sqrt L (WL in feet) As a boat gather speed, it commences to settle bodily in the water with the bow usually sinking a little more than the stern. As the 2nd wave crest passes the stern (S/L 1.34) the bow starts to lift and the stern to fall, until there is a pronounced bow-up trim. This state of affaris continues until a S/L of abit 2 is reached. Now the stern will start to rise, and with it the CG of the boat as a whole. At about S/L of 2.5, the CG will be back in its original (at rest) position. The CG continues to rise with further increments in speed. At a S/L of about 3.5 the boats trim will, or should, start to flatten out and it will loose some of its bow-up attitude. Water rushing along the bottom and meeting the wedge shape presented by the immersed hull will continue to lift the stern and the craft as a whole, until it is running flat and hight in the water. The boat is said to be planing when, with the boat in motion, the CG is back at the same height as it was when the boat was at rest. Physical evidence of the boat achieving the planing mode, ie exceeding speed hump, is water separating cleanly at the chine and transom.
#28
| Will says: "Physical evidence of the boat achieving the planing mode, ie exceeding speed hump, is water separating cleanly at the chine and transom." But, but.... this can be achieved at anything more than 3 knots in some boats, with waterlines of 40 feet and up...... If you assume a deeply immersed transom, then "Yes", they are as correct as they need to be. ;-) |
#29
| Entering wedge No, entering wedge is based on an infinite Froude number added mass analysis. The most recent one uses something very like the kind of close fit theory used for ship motions in Hansel or SMP. |
#30
| I've always been confused about the measurement of waterline length. It changes dynamically with speed. Many good designs use this change to their advantage. For example, overhangs on a hull. A fast boat may have 10% of the waterline at planing compared to displacement speed. Which waterline do you measure; the one at the particular speed or at rest? |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 07:01 AM |
| Building my first boat. | ihallenius | Boat Design | 18 | 08-03-2005 01:02 AM |
| Concept Boat Design Contest | Tad | Boat Design | 16 | 09-17-2004 10:13 AM |
| Restoring an old boat, starting with the floor. | jsass | Boatbuilding | 7 | 06-24-2004 08:56 PM |
