Longitudinal postion of the centroid of the area curve should be the LCB. |
| This is what Freeship/Delftship does so easily - its really worth the trouble unless you need the brain strain. |
| Using FreeShip, DelftShip or any other software doesn't make you a yacht designer (or a naval architect!) They are just advanced calculators that make life easier for the user. It seems to me that what you need is to read a book about yacht design. Principles of Yacht Design by Larsson & Eliasson would be a good choice. BTW: "SA" is normally used for Sail Area. Wetted Surface Area is shortened "WSA".
__________________ Best regards, Søren Flening NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects. |
| Hi, if You want to enter the matter, and understand things too, even if less known, Gauss-Legendre integration method, with 4 integration points, is very fast and precise, once you can make a diagram or a tab. of the integrating function (example, cross sections area to calculate the volume, wet beams to calculate hull wetted plane, wetted contours to get wetted surface, and so on...) and it fits well also with automated software procedures (sample: http://www.idet.it/idra.html). Bye K. |
My only interest in Freeship is to do a stability calculation and find the swamping angle, which would take forever if I tried drafting the design displacement at so many angles of heel. I think pushing points around in 3D software is very misleading...especially when you're looking at the cool model which may or may not actually be a good design. Quote:
But yes, I look forward to seeing if my numbers match to what this kind of program says. |
| Thanks everyone for the replies. |
Tim, if you are interested, I can send you copies of my Excel spreadsheets (10 & 20 stations) based on Simpsons multipliers, basically in the same photo copy format as shown by Doug. It calculates Displacement, LCB, VCB, CP, CWP, immersion and moment to trim all on one page. Another spreadsheet calculates water-plane area and center of flotation. If interested Tim, just send your email by PM and its off to you.
#25
| Check your email Tim, the postman has delivered ![]()
#26
| Wynand, those are very nice spreadsheets! Thanks again. |
#27
| FreeShip gets discussed a lot in these pages. If you do a forum search - or use Google's site search which is more powerful - you will find lots of threads with information. Programs like FreeShip are specifically for hull shape design. If you can find a free download for Carene2008, that is a very easy and intuitive program for a beginner, although less flexible. It's exported offset tables will import directly into FreeShip: this is a route I sometimes take to get into FreeShip's tools quickly. If you're likely to design more than one hull the learning is worth the effort. Last time I looked the Freeship manual was a pain several inches above my kayak's seat but there was a tutorial on the net which was good. Search and ye shall find . . .
| Planing Hull at Disp Speeds | Easy Rider | Boat Design | 91 | 10-13-2010 10:03 AM |
| Math Question | Mark Emaus | Propulsion | 31 | 03-22-2010 03:16 PM |
| More questions (Priogue) and math. | jdarling | Boatbuilding | 9 | 07-02-2009 03:18 PM |
| Question about Disp/Lwl | Chuck Losness | Boat Design | 8 | 01-11-2009 12:39 PM |
| Looking for math/algorithm forums | nico | Software | 1 | 11-07-2006 08:49 AM |
