Old 04-03-2008, 03:57 AM
Jet FiSH Jet FiSH is offline
Rep: 10 Posts: 15
Material masses and reccomendations.
Looking for the masses of materials for the displcement calc's.
i.e. mass of 1mm ply per meter squared
mass of fiberglass per meter squared per mm
solid foam mass per meter cubed
also what would you guys reccomend for a hard chine in a single chined v planing hull? (small) something like H3.2 treated 25x50 (1X2) ??haha
also how do you bend plywood and mold it? do you steam it then screw it in place, i.e. for a femal plug?
many thanks
FiSH
Old 04-03-2008, 05:02 AM
rwatson's Avatar
rwatson rwatson is online now
Rep: 1188 Posts: 2,397
Thats a bit unrealisic - what type of plywood? what type of foam ? if you know what material you are using, the manufacturers will give you the weight.
You dont even provide the size fo the boat with the single chine. Are you over 18?
Hey - one litre of water = 1 kilo, unless its sea water then ....
Old 04-03-2008, 08:28 AM
Omeron Omeron is offline
Rep: 31 Posts: 163
What you are looking for is the specific gravity of marerials.
If it is a composite, find out what pecentage of what has gone into it, then do the math...
Old 04-03-2008, 08:56 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Worksheet:
http://hyperphysics.phy-astr.gsu.edu...lab/densi.html
Simple Chart:
http://www.npl.co.uk/server.php?show=ConWebDoc.1385
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Foam is sold as being, say 750, which is in fact its weight.
Old 04-03-2008, 02:37 PM
Rep: 10 Posts: 15
deck length approx 2m at this stage.
lwl unknown at this stage
12 degree deadrise at transom
20 degree deadrise at midships
330mm freeboard at midships
420mm max beam at midships and same at transom
yeh ok i guess it was a pretty vague question.
yeh im 17, why?
Old 04-03-2008, 07:31 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Here are the numbers I use from my own measurements.
Occume plywood =.102lbs/mm/ft^2 = 1.098lbs/mm/m^2
meranti plywood = .126lbs/mm/ft^2 = 1.356lbs/mm/m^2
keroung plywood = .144lbs/mm/ft^2 = 1.55lbs/mm/m^2
The keroung may be something else, which is anybody's guess.
There are other plywoods that have various number of plies and various woods used for inner plies so some weights may fall between these figures. Some Chinese plywood I have run into lately is all over the map. I have recently even seen some plywood supposedly rated as marine that had metal staples hidden inside. I speculate that these are used to connect the edges of interior flitches instead of using gluing edge-banders like they should. The staples look just like the office desk type and are likely a way to use cheap labor instead of machines.
I ran some boil and soak testing on the heavy stuff. The glue passed the tests just fine. After a day in the water, it absorbed enough to sink to the bottom. Not what I want in my boat.
Tom Lathrop
Old 04-03-2008, 11:38 PM
Rep: 10 Posts: 15
awesome, cheers man!
and how do you mould the ply?
Old 04-04-2008, 04:49 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Go to the following sites.
http://www.bluejacketboats.com/
http://bateau2.com/content/section/5/28/
http://www.glen-l.com/
http://www.devlinboat.com/sgfp.htm
Read, mark and inwardly digest.
Pericles
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 04-05-2008, 12:09 AM
Rep: 10 Posts: 15
Thats premo man!
fantastic
material help please madmatt Fiberglass and Composite Boat Building 4 12-02-2006 01:33 PM
a sugestion to the masses... greg simpson Open Discussion: All Things Boats & Boating 18 02-21-2006 01:55 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 08:29 AM
Best Material Aquaholic Boatbuilding 1 09-25-2004 05:27 PM
Plan to fit sail kit - Any reccomendations? DrewBird Wooden Boat Building and Restoration 4 06-05-2004 06:12 PM
