Old 03-13-2006, 06:34 AM
Tom_S Tom_S is offline
Rep: 10 Posts: 3
Mast pillars design
Hello,
I'm designing a sailing boat (7.5m, cruising), and a mini 6.5, and i have to put a mast pillar in both boats. Could someone give me some informations about how to design it (forces acting, the way to dimension the bolts)?
Thanks
(sorry i put the same question in the sailboats forum...)
Old 03-13-2006, 06:40 AM
dimitarp dimitarp is offline
Rep: 19 Posts: 89
First you need to determine forces that acts at the mast. For this you need to know area of saels and the maximum speed of wind.
Old 03-13-2006, 03:59 PM
Rep: 1729 Posts: 2,462
Righting moment only
Getting there.... but not quite. The max force is due entirely to the ability of the boat to resist the wind heeling moment.
what you actually need is the maximum righting moment. Pretty accurate to use RM30 X 1.5 .
If you take the moment and divide it by the mast height you will get a force normal to the mast head, you now need to calculate a force diagram and find the resulting compression in the mast. Give yourself a factor of safety of around 3 .
If this is beyond you give me the dimensions and the RM and I'll calc it for you.
If you have not calced your RM then thats the next step.
Mike Johns.
Old 03-14-2006, 02:29 AM
Rep: 10 Posts: 3
Thank you, my next step will be indeed to calculate my righting moment...
Old 03-14-2006, 11:15 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Tom_S mast pillars are the same as a mast they are under compression so you can use Euler’s formula for the appropriate end condition to work out loads.
Mast pillars design Tom_S Sailboats 1 03-13-2006 08:41 AM
Mast design help needed fazmac Boat Design 0 12-12-2005 10:55 AM
Dinghy Mast Design kenwstr Sailboats 11 11-15-2005 10:36 AM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 09:55 AM
Interesting Mast design mytqik Boat Design 3 12-20-2002 01:03 AM
