| Mast Making Mast making seems to be underdiscussed--maybe even its becoming a kind of 'lost art'? Here's a link on making a mast using the "birth's mouth" method. http://www.frankhagan.com/weekender/mastm.htm Feel free to post other good mast-making links or mast-making tips on this thread. |
| Not that hard to do in carbon, either. You do have to think about more issues obviously, but still within reach of the 'gifted amateur', given you get a proper engineer to design the layup. The braided and Uni sleeve from A & P Technology is ideal for this purpose. http://www.braider.com/index_lo.html Now 'all you need' is a mold, oven, compaction method and slow curing resin system and you're there! Jimbo |
| that is good method... hollow mast I use a big log and downsize it to scape the outer skin... waste a lot of lumber but good for my own boat...
__________________ Student |
| Just a thought Why couldn't you build it in half and join it together with epoxy and then use Kelvar/Carbon fibre to seal it up on both inside and on the outside once you have glued the two pieces together? |
| Making Curves - is this one way? | kach22i | Fiberglass and Composite Boat Building | 35 | 06-02-2008 05:44 PM |
| just making sure I've got it right | martinf | Boat Design | 9 | 12-07-2007 08:18 AM |
| mast design-how do you go upon calculating the effect of the sail on the mast??? | airturb | Sailboats | 34 | 02-21-2005 10:55 AM |
| making foils? | sigurd | Sailboats | 4 | 07-06-2004 07:33 PM |
| Making Moulds | Daz K | Fiberglass and Composite Boat Building | 18 | 05-25-2004 06:48 PM |
