Old 01-27-2010, 03:26 AM
coupedesign coupedesign is offline
Rep: 34 Posts: 4
Manual furling boom
I designed some boats with hydraulic system, that are not easy to use. Anyone know something about the manual system?
Old 01-27-2010, 04:19 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
There are some manual gear in >~100 year old gaffers.. simple robust and reliable.. maybe worth of some R&D. Tried to google but didn't find pictures. In Tom Cunliffe's book Hand Reef and Steer there's one picture and a chapter atleast..
Old 01-27-2010, 04:55 AM
Rep: 34 Posts: 4
Do you know "johnmast" mechanism.
My fear is" what happen when system fail?"
I'm going to install in a sailboat for a 65 owner so if he will have problem with the furling mechanism, feeder makes harder the falling of the sail.
Don't you think could be safer a mast trak with roller car?
Old 01-27-2010, 05:30 AM
TeddyDiver's Avatar
Gollywobbler
Not my specialty, sorry.. I'm quite skeptic what comes to furling gear "into" anything. Maybe someone with real experience will show up.
Regards Teddy
Old 01-27-2010, 07:18 AM
Rep: 1493 Posts: 7,447
I have used worm drive furlers in several boats. They work great and the maintenance is minimal. The sail has to be cut properly or it won't furl right.
Old 01-27-2010, 07:41 AM
Rep: 34 Posts: 4
Well, marten make an eliptical mendrel where you may roll up a 3DL north.
However in manual use you never have probem? Do you think will be safe enough for an old user?
Old 01-27-2010, 07:48 AM
Yes I think it is safe. The good thing about a boom furler, is that you can always roll or unroll the main manually if the drive breaks or jams.
Old 01-27-2010, 08:13 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
What size boat/sail are we talking about.I am building a system for my 26ft boat which will be similar to what is used on the Corsair trimarans which have a shaft through the mast with a crank on the front,no gears and just a regular bolt rope luff.I have a thread going on sailing anarchy multihulls forum asking questions of actual corsair owners which you may find useful.I am going to use a bolt rope but i will enter the bolt rope a long way up through a prefeeder. I have installed a profurl in boom system for a customer before but it is very complicated and expensive and achieved the same goal.
Steve.
Old 01-27-2010, 08:17 AM
The through mast with a u-joint is the Herreshoff system from about 1930. It is simple
Roller reefing/furling boom Steve W Boat Design 0 09-20-2008 10:07 AM
broken boom- mid-boom sheeting problem? somedaypam Boat Design 14 10-25-2007 09:14 AM
Wishbone Boom Versus Conventional Boom Doug Halsey Sailboats 31 06-04-2007 04:05 PM
Reckman furling Alik Boat Design 2 01-17-2006 07:04 AM
Jib furling system, below deck hha Marketplace 0 01-24-2005 03:30 PM
