| Manoeuvrability catamaran I'm designing a workboat for the northsea. Dimensions: LOA 17 m, BOA 6.5 m, speed of more than 20 knots. I would like to hear your thoughts about the manoeuvrability (at low speeds) of a catamaran versus a monohull. |
| At low speeds cats have excellent maueverability due to bigger distance between engines, and ability to reverse the engines. They just need different driving technique compared with monos. At high speeds - yes, cats have bigger turning radius. |
| Thank you Alik. I know cats are generally harder to maneuver in high wind speeds because of the smaller underwater ship. But why do they have a larger turning circle? They drift more? |
| They have a larger turning circle at speed because they have more lateral resistance than say a planing monohull. If you put small permanent skegs on the hulls near the shafts, cats gain a lot more manouvreability. But as said above, low speeds, cats win, especially if you put the rudders nice and close to the props as well. Regards, Andrew. |
Lager turning circle is due to group of factors: higher inertia, higher hydrodynamic damping of turning motion, etc. Actually cats possess about double hydrodynamic damping compared with monohull craft. Recently I have presented a paper on catamaran design at CPBS, there is some data on turning diameter of catamarans. |
| Thank you for the explanation! Can i find your paper somewhere on the internet? Sounds really interesting. (Sorry, don't know what CPBS is) |
| need a catamaran | navaleng | Multihulls | 7 | 12-10-2008 12:42 AM |
| 32 catamaran | seanform | Boat Design | 0 | 07-19-2007 05:43 AM |
| 5 m Catamaran | joaopereira | Multihulls | 1 | 04-18-2006 04:12 PM |
| Catamaran Tender for Catamaran | b_rodwell | Boat Design | 4 | 02-18-2006 09:01 PM |
| Boat manoeuvrability | Alik | Boat Design | 3 | 09-17-2003 09:17 AM |
