Old 05-23-2004, 03:32 PM
paffka paffka is offline
Making a log raft
Hello, I'm really new here.
I just began work on a log raft on my own that's gonna be used for some precision fishing. I began by sawing some logs, each from an eucalyptus tree. This brings me to my first question.
Is dry and dead wood more buoyant than green and bendy one? The live ones I obtained had some waterproof coating but felt heavier.
Each log is roughly 2.25 meters in length and 10 cm in diameter. I plan on stacking two levels of these and attaching them with centerboards and some nails. For extra measure, I'll also attach a dozen big water bottles underneath.
My second question: How can I attach them firmly to the wood?
You know the length but the width will be about 1.5 cm. I'm expecting to carry about 60 kgs of weight when I board. I won't bother with a sail but should I attach a large tiller below to avoid capsizing?
Old 08-12-2006, 06:57 PM
djwkd's Avatar
djwkd djwkd is offline
Rep: 51 Posts: 380
possibly tying them on,then supporting them with gluer or nails (note i said 'SUPPORT' not 'OR INSTEAD')
Old 08-13-2006, 09:29 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,728
Yes, the wood is wet, full of sap, and significantly heavier.
make nets for the bottles and lash them
I think you mean 1.5 m, and a tiller won't do much to help with capsize. You would be better off by offsetting a log as a pontoon on each side.
Steve
Old 03-28-2007, 12:13 PM
djwkd's Avatar
Rep: 51 Posts: 380
yes, two logs on either side with wide planks nailed in over the top-excellent idea.
Old 03-28-2007, 07:28 PM
im412 im412 is offline
Rep: 5 Posts: 61
here's a native one
Old 03-28-2007, 11:47 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
NO NAILS!! Lash with polyethelene rope OR thru bolt (or rods).
DON"T put the barrels "under" anything. Use net as advised but affix along the sides. If you put them under, they will be a source of constant trouble.
There is a reason we use "waterlogged" to describe items that are barely floating. Bouyancy equalls displaced air. The drier (no sap) the log, the more air pockets.
Rafts can be fun (and cheap).
I think I would bundle 3 or 4 logs, tight together to make a BIG log for each side of your raft. This allows some of those logs to ride above the water and dry & remain dry. This is better than the same number of logs spread out I think.
Have fun!
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 03-31-2007, 05:16 PM
ted655's Avatar
Rep: 122 Posts: 641
http://www.floatingneutrinos.com/Oth...he%20rafts.htm
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 11:23 AM
building a raft on $75 Captain Mark Open Discussion: All Things Boats & Boating 70 01-04-2010 05:03 PM
Easiest (i.e. cheapest) way to build a raft + rafting disaster! Spyder Ninja Boatbuilding 31 02-20-2009 10:58 PM
More of a raft really... ace rockola Boat Design 7 03-22-2007 03:32 AM
Aluminum dinghy/life raft... bobola Boat Design 3 07-29-2005 09:04 AM
