Old 08-04-2011, 02:04 PM
DavidJ DavidJ is offline
Rep: 433 Posts: 151
Making a lines plan from an existing boat
Hello does anyone know of a method for making a lines plan from an existing vessel WITHOUT taking the boat out of the water? If it has been done how accurate was the resulting model?
A client requires a full stability analysis for regulation compliance however there is no lines plan available. I have experience taking offsets from a hull so I know what is involved in the normal procedure, but this is a 40m+ vessel that would require dry docking. Around the office we are discussing using a laser level to obtain points on each side of the hull and measuring from the inside of the plating at frame locations. Aside from the obvious difficulties involved with finding shell access in accommodation spaces, could this work?
My gut feeling is that it would be possible to create a hull but the accuracy would poor. The keel alone would have to be a complete guess.
The vessel is a round bilged, transversely framed, welded steel construction, motor yacht registered as a passenger ship.
Old 08-04-2011, 04:42 PM
Rep: 1493 Posts: 7,447
Using a level on a floating boat is a landubber's idea. It will not work. It should be fairly straightforward to take measurments of bulkheads with a jogging/pickup stick and then transfer them. You can then use the bulkhead spacing to draw the lines. You just have to add the skin thickness and whatever appendages there may be.
Old 08-04-2011, 07:33 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Talk to a local surveyor, the land/civil engineering type, especially if you can find one who has experience with measuring equipment and piping in manufacturing plants, etc.
Old 08-04-2011, 10:47 PM
Talk to any shipwright or boatbuilder. It is a simple procedure that is performed on a daily basis.
Old 08-05-2011, 02:17 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,251
If the purpose of this operation is just to satisfy bureaucrats and get a stamp and signature, take the lines plan from a lookalike and scale that up or down using just a few measurements made with a laser or an ultrasonic device.
Yes, the keel will be pure guesswork, but does that bother anyone?
Old 08-05-2011, 07:47 AM
I wonder what happened to the original lines. They should be filed somewhere with the original permits.
Old 08-05-2011, 08:02 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
I would me more worried about how to make the weight analysis.. The only proper way to make this is to produce a similar hull (with delfship or similar softw) including all plate thicknesses, tanks, gear etc.. IMHO
That is off course if just a evaluation of Metacentric height and roll period isn't enough..
Old 08-05-2011, 12:00 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
While the stability analysis is created to satisfy bureaucrats rules, it is also a verification of how safe this vessel is for the passengers. And David's head will role if there should be an accident...He is taking responsibility for the safety of those unsuspecting holidaymakers....he must be sure (doubly sure) of his data.
Yes, take all the measurements you can inside the hull. Find photos of the boat on the hard to correlate with. Then hire a diver to measure the keel and transom, locate the bow thruster, etc. You can even make a big aluminum adjustable square(adjust with c-clamps) of two pieces of angle bar. Hold this upside down in the water with a point against the hull, mark the waterline and distance off centerline....probably with the help of a diver (make sure the hull is clean at measurement points) and a couple of levels....a long days work.......but possible.......
Old 08-05-2011, 02:46 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Actually, it may be possible to use a software package and underwater photos to get the hull lines within a very high degree of accuracy. Photomodeler is the only software I'm familiar with, and it uses reflective targets on the "object", the focal length of the camera and a few known distances (as well as dozens, if not hundreds of photos), to produce a surface model. The more photos, the smaller the error, the higher the accuracy. You could do the same thing inside the hull too.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 08-05-2011, 02:59 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Presuming you can see through the water.......
Old 08-05-2011, 03:41 PM
Engineer
In principle yes but .....
- The water would need to be sufficiently clear.
- The camera/lens would need to be calibrated underwater though with enough photos a "field" calibration might be possible.
Old 08-05-2011, 03:42 PM
Engineer
For the interior it might be hard to get photos from enough different angles which share sufficient points.
Old 08-05-2011, 09:15 PM
Rep: 1729 Posts: 2,462
Originally Posted by DavidJ View Post
Hello does anyone know of a method for making a lines plan from an existing vessel WITHOUT taking the boat out of the water? If it has been done how accurate was the resulting model?.........
Yes I've done it quite accurately measuring inside, but it depends what the access is like.
Use land surveyors tools, tapes laser levels, and an audio distance gauge is useful too. Photograph everything helps remember where they all relate, work from transverse frames and bulkeads and correlate everything with measurements of deck and topsides with plumblines from the sheer. Give it a full day and 2 people. Be prepared to go back a couple of times to check the apparent anomalies.
Mike Johns.
Old 08-05-2011, 11:51 PM
Any shipwright worth his salt can do it with a tape measure a few sticks, paper and pencil. There is no need for software, even though it may be made to work.
Old 08-06-2011, 03:03 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
& put him in a wetsuit with a few clamps, sticks, datum wire, 2' square & a tape measure & a digi camera & you'll get the keel etc too.
Parabolizing lines of existing hulls Leo Lazauskas Software 45 11-23-2009 09:41 AM
Pulling Lines off an Already Existing Hull/Mold bobby_mcgrath Boat Design 5 12-06-2006 07:12 PM
Taking the lines of an existing hull waterman Boat Design 29 03-16-2006 03:30 PM
Modelling in Maxsurf with existing lines plan squivo Software 1 03-07-2006 03:35 AM
Legality of “Borrowing” Lines from Existing Hull Design CET Boat Design 55 02-04-2006 07:26 PM
