Old 02-07-2009, 11:05 AM
meebo meebo is offline
Rep: 10 Posts: 7
LR Rule Length......
Hello,
LR rules define the rule length as:
6.2.1. Rule length, LR, is the distance, in metres, on the summer load waterline from the forward side of the stem to the after side of the rudder post or to the centre of the rudder stock if there is no rudder post. LR is to be not less than 96 per cent, and need not be greater than 97 per cent, of the extreme length on the summer load waterline. In craft without rudders, the Rule length, LR, is to be taken as 97 per cent of the extreme length on the summer load waterline. In craft with unusual stem or stern arrangements the Rule length, LR, will be specially considered.
6.2.2. Length between perpendiculars, Lpp, is the distance, in metres, on the summer load waterline from the fore side of the stem to the after side of the rudder post, or to the centre of the rudder stock if there is no rudder post. In craft with unusual stern arrangements the length, Lpp, will be specially considered. The forward perpendicular, F.P., is the perpendicular at the intersection of the summer load waterline with the fore side of the stem. The after perpendicular, A.P., is the perpendicular at the intersection of the summer load waterline with the after side of the rudder post or to the centre of the rudder stock for craft without a rudder post.
May anyone tell what is the difference between LR & Lpp? How can I define LR for planing boat with outboard engines?
Thanks in advance
Old 02-07-2009, 05:44 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1925 Posts: 3,025
"...LR is to be not less than 96 per cent, and need not be greater than 97 per cent, of the extreme length on the summer load waterline. .."
There is your answer
Old 02-07-2009, 11:39 PM
Rep: 10 Posts: 7
Dear Ad Hoc;
I already noticed what you mentioned (LR<=97% load line) but how can I specify both of LR & Lpp for boat with outboard engines, it doesn't has rudder stock or post; I this case can i consider Lpp=LWL ?
could you please draw a sketch for this case & specify Lpp, LWL, LR?
Should I consider LR as an absolute figure that can't be specified on a drawing?
I read in on of your posts that your are LR Tech Committee member, hope you could help me in this regard.
Thanks
Old 02-08-2009, 04:57 AM
Naval Architect
You're getting confused for the very obvious reason, LR rules, like all, are based around the hull envelope and what is inside it, or protruding from it. If your engine is an outboard, the above assumptions do not apply, ergo one defaults to the easiest:
Ask yourself this Q...what is the definition of LWL and what is the definition of Lpp....just look in any naval arch book if you're not sure. QED.
When you run the numbers of 96% and 97% on a small boat, you'll then realise it makes zip difference which value you select. In other words the prescriptive rules that you are using have values which are really outside the scope of the parameters for said rules.
Old 02-08-2009, 06:24 AM
ringoo83 ringoo83 is offline
Rep: 26 Posts: 54
Originally Posted by Guillermo View Post
"In craft without rudders, the Rule length, LR, is to be taken as 97 per cent of the extreme length on the summer load waterline."
"Lpp, is the distance, in metres, on the summer load waterline from the fore side of the stem to the after side of the rudder post, or to the centre of the rudder stock if there is no rudder post. In craft with unusual stern arrangements the length, Lpp, will be specially considered."
In my opinion Lpp is equal to the designed hull waterline length and LR 97% of that, for an outboarded boat. But to be more sure, you can ask Lloyd's (rules@lr.org)
Or then:
Classification and Quality Services Gozetim Ltd Sti.
Ataturk Caddesi, Sitki Bey Plaza, No.82, Kat.3 Daire.12, 34742 Kozyatagi, Kadikoy
Istanbul, Turkey
T +90 (0)216 368 9930
F +90 (0)216 386 2997
E istanbul@lr.org
Cheers.
I agree eith this
Old 02-10-2009, 06:26 AM
Naval Architect
Meebo
Yes, I am on LR's Tech Committee.
Lpp, is simple, length between perpendiculars.
Lwl, length on the waterline; for almost every design, is the same as Lpp
LR, is just a fudge factor for LR calc's. (From big ship stuff)
So, if you can't ascertain the LR, just use, not less than 96 per cent, and need not be greater than 97 per cent of Lpp/LWL. The difference is minor on 'smaller vessels'.
LR rule length>>>>help meebo Class Societies 5 04-20-2009 11:39 PM
IOR Ton Rule SuperPiper Sailboats 16 05-15-2008 12:46 AM
time for a new ACC rule? nflutter Sailboats 72 07-06-2007 04:10 AM
new rule for the WOR 70 Tanguy Boat Design 2 11-27-2003 09:31 AM
IMS rule Hannu Rantala Boat Design 1 08-08-2003 05:41 AM
