Old 01-17-2007, 11:29 AM
LinedTheBlind LinedTheBlind is offline
Rep: 10 Posts: 13
Low Water Pick-up and Jackplates, worth while?
I'd like to get some feedback from anyone who is knowledgable about transom-mounted water pick-ups (or low water pick-ups) which, in conjuction with a jack plate, allow you to raise an outboard up higher to run in shallow water. I've got just a small 20hp outboard.
How far (inches) can the motor typically be raised up with a transom mounted pick-up? How much clearance would i gain by adding the pick-up?
I have a small boat and won't be adding a hydraulic jack plate, but could add small manula plate. Can I run at top speed with the motor permanently set at a shallow water hight?
Thanks.
Old 01-18-2007, 09:12 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
I just added a hyd. jackplate. Got it from this site
http://www.bobsmachine.com/
They have good tech support, ask them. They offer both types. Trnsom & lower unit.
You will need a water pressure guage for sure.
I choise not to use a pick up (yet anyway) be cause I will just use mine to lift over things here in the swamp. I won't be extended running. I asked the same question as you have. Maybe someone will answer us both.
Set your lowest height so the cav plate of the motor is 1/2" above the boat hull bottom. Most plates lift 6""
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Jackplates for sale Sgray Marketplace 28 08-06-2008 10:44 PM
Transom Water Pick-up, Any Benifits? LinedTheBlind Outboards 3 02-09-2007 06:59 PM
I want to pick your brains :D student.matt Boat Design 1 07-12-2006 02:04 PM
Jackplates and extension on aluminum boats Bobber1 Metal Boat Building 5 03-24-2005 11:36 AM
Low power tunnel, low speed drive robrohdeszudy Propulsion 9 12-23-2004 04:09 PM
