| Low Drag Propulsion System I am interested in developing a low drag propulsion system for very high-speed craft that uses rotating cylinders (configured much like the tires on a car). My intent is to use the boundary layer to provide thrust. Yes, I do realize that this either means I need very high surface area and quite high roatation speed to get a thick enough boundary layer do acomplish anything, but I think it would be acheivable. I've seen this somewhere before though, and I can't remember. Has anyone else seen this type of system??? |
| Check out Brunel's experiment between screw propeller and paddle-wheel. Consider now the high performance powercraft (class 1 offshore - surface piercing props) and the high-power commercial craft (many using waterjets). The common feature being a propeller of some type. Yes, a rotating cylinder in a fluid will produce a force, but it is unlikely to do it as efficiently as a propeller. The major advance of the water-jet over the marine prop was the reduction in cavitation, as the speed was higher, and the pitch lower, thus preventing to a large extent cavitiation. Also, because the water is in a rigid tube, and is itself incompressible, that reduces the chance. Don't get me wrong, I'm not trying to put a damper on you're enthusiasm, but this is not a simple area, and the waterjet is efficient for more reasons than I have mentioned. So the question becomes, is it a revolutionary system, or a revolution in an existing system's efficiency? If for instance, there is a correlation between propeller pitch and speed (but we don't want it to cavitate when we slam the throttle open) then perhaps that systems control and blade optimisation would be a possible way to go. Perhaps even using sensory equipment on the blades to detect cavitation, and reduce pitch/speed accordingly. Just an idea. Tim B
| I did look at water jets, but my only issue with them was that (obviously) the intake has to be immersed I am hoping to get the hull an inch or more above the water surface. The Tesla turbine info that I got was encouraging, but a little suspicios, with claims of efficiency in the 90% range. I have seen SNOWMOBILES recently racing on a lake in about 3 feet of water, supported only by dynamic lift and propelled by their usual caterpiller track. |
| Re: snowmobiles Quote:
I thought I had seen a story about an inventor earlier this year who came up with a virtually cavitation free screw drive, but I can't find it. In the mean time check this out http://www.olds.com.au/marine/maximi...cy/Default.htm I hope this helped, -Dom www.idfuel.com |
| Hovercraft? Quote:
Good luck and hope to hear more, Dan |
| Some ideas | yipster | Projects & Proposals | 81 | 02-15-2006 01:32 AM |
| New propulsion System | tom kane | Open Discussion: All Things Boats & Boating | 35 | 06-09-2005 01:06 AM |
| Another new propulsion system | DEDave | Boatbuilding | 12 | 09-09-2004 11:25 PM |
| Propulsion system drag | CAS | Powerboats | 5 | 11-19-2003 01:32 AM |
| New jet propulsion system | Guest | Boat Design | 10 | 10-30-2003 04:28 PM |
