| A Tuned Hull Plus Low aspect ratio sail is fast. My design for the simplest flying wing simply added a modern sailplane cockpit to a low aspect ratio wing with a symetrical section. This design exceeded conventional wings by a large margin. Why? Because a flying wing is the most efficient by far. Remember that as apparent wind doubles the wing or sail area can be reduced to one quarter the area for the same thrust. |
| A Tuned Hull Plus Low aspect ratio sail is fast. My design for the simplest flying wing simply added a modern sailplane cockpit to a low aspect ratio wing with a symetrical section. This design exceeded the performance of conventional wings by a large margin. 40 horsepower, 150 knots as an example. Why? Because a flying wing is far more efficient. Remember that as apparent wind doubles the wing or sail area can be reduced to one quarter the area for the same thrust. Add to this the fact that when conventional angles of attack are exceeded a powerful vortex is generated along the leading edge of the short span. The wing or sail now has a lft co-efficient typically four times greater than a conventional wing or sail. Note also that wingtip foils, except at vry low speeds, are purely for pzazz. They actually detract from performance at speed! Cheers, Lin Olen |
| I am trying with an iceboat,wish me luck |
| I hope you're not too crazy, because if you are, I might be too! See my post at the bottom of the page at: wingspar sail rig |
| Low Speed Surfacing Propeller | dgruenwald | Surface Drives | 19 | 01-28-2010 11:16 AM |
| low-aspect foils and tacking | rayaldridge | Boat Design | 0 | 07-12-2006 05:44 PM |
| Low power tunnel, low speed drive | robrohdeszudy | Propulsion | 9 | 12-23-2004 05:09 PM |
| high aspect keels - construction | samh | Boat Design | 1 | 11-15-2004 01:18 AM |
| Is this the right prop for this low speed inflatable? | bill fish | Powerboats | 0 | 07-30-2004 12:57 PM |
