Old 07-12-2006, 05:44 PM
rayaldridge's Avatar
Rep: 292 Posts: 572
low-aspect foils and tacking
Am I correct is assuming that tacking a boat with low-aspect ratio foils (all else being equal) will be more certain than tacking a boat with high-aspect foils, due to the greater stall angles of the low-aspect foils?
I ask because I'm working on a small catamaran design in which high speed is not the primary goal. I assume the dominance of high-aspect foils in racing catamarans is due to their better lift-drag ratios, but in my case, I want a well-behaved boat. Is this a possible design trade-off?
One more clarification: I'm not talking about LAR keels as in some production multis. I'm talking about aspect ratios under two in conventional transom-hung rudders, and perhaps a more conventional high-aspect ratio daggerboard.
Ray
Canters tacking usa2 Sailboats 19 07-11-2010 09:10 PM
Mast heights, boom lengths and aspect ratios Allan Jennings Sailboats 17 12-02-2005 11:40 AM
amateur high aspect bulb keels nitz Fiberglass and Composite Boat Building 1 11-08-2005 11:22 PM
Low power tunnel, low speed drive robrohdeszudy Propulsion 9 12-23-2004 05:09 PM
high aspect keels - construction samh Boat Design 1 11-15-2004 01:18 AM
