Old 09-16-2004, 03:18 AM
Daren
Looking for wood species in Asia for strip planking
I live in Cambodia. And I'm looking for an asian species of wood which will fit with strip planking boat building method requirement.
Today, it's difficult and very expensive to import traditionnal wood like Red Cedar, so I would like to use a local species.
Is anyone can help me ?
What are the requirements for a wood to be a good strip planking wood ?
Is it possible to stripplanked with marine plywood lumber ?
Thanks to all for your help
Daren
Old 09-16-2004, 04:17 AM
Rep: 66 Posts: 640
Daren
Daren,
Rather then asking us what you should use, tell us what you have available!!
Then we can recommend on your best option!
What do you mean with marine plywood lumber? Leftovers or the lumber used for plywood and that would be what species then?
Dutch Peter
Old 09-16-2004, 04:58 AM
Daren
Peter
I've made a mistake
I was asking if I can use plywood strips in order to use red cedar strips !
I will make a listing of the useful species from here but if someone have the answer it's great
Old 09-16-2004, 05:15 AM
Rep: 66 Posts: 640
Daren,
It depends a bit on the size of boat. I'd think plywood strips are fine when you build a 3-5 mtr boat, specially when you apply a coat of glass.
On larger boats I would stay with the cedar strips!
Dutch Peter
Old 09-17-2004, 05:57 AM
Daren
Wood species
Here are the common species which are easy to find
Cunninghamia lanceolata, Pinus massoniana, Pinus tabulaeformis, Pinus elliottii and Larix spp
Populus spp. Eucalyptus, Paulownia elongeta, Pinus fortunei, Casuarina and Acacia auriculiformis
Tectona grandis
Old 09-17-2004, 05:59 AM
Rep: 66 Posts: 640
Tectona grandis
I'll have to look that up in my Woodbible, will be after the weekend!
Dutch Peter
Old 09-17-2004, 04:06 PM
Rep: 472 Posts: 614
Plywood is useless in Strip planking. It's less rigid and you'll add concerns about glue. Sanding through cross grain is a pain....
Stay with wood...Scientific names won't be of great help at the lumberyard. I doubt that the guys know the wood by their scientific names....
Better go to see the lumberyards, ask the carpenters and cabinet makers. Touch the woods, weight, evaluate, choose one and take the risk to try it.
Old 09-23-2004, 11:54 AM
seamonkey seamonkey is offline
Registered
Rep: 10 Posts: 40
...I'm not sure of the latin names,but if you have mahogany in the right thickness to take your shapes,it might be good.
Old 09-29-2004, 09:57 AM
jusembo jusembo is offline
Rep: 2 Posts: 44
Hello,
I'm buildind cold-molding in South of China in Yellow-Cedar we also have Catalpa which sould also be suitable for molding.
Maybe you can find theses species in Cambodge as we are not so far
Maybe Teak should be a solution but i don't know much about this wood as we don't have it in China
Regards David www.solalelouna.com
Old 09-29-2004, 10:27 PM
maneck maneck is offline
Rep: 10 Posts: 2
Wood to substitute Red ceedar
Hi, I live in India and have had to improvise on our boat building projects. Fortunately for us red ceedar does grow here and we do use it extensively in our boat projects. Having worked with it our advice would be for you to look for a wood which is light , straight grained with contineous fibers and knotless . the other points to note are as below.
1. ensure the wood is seasoned .
2. preferably should be cut in autum ( less sap in the tree ie less water content in the wood )
3. study the grain of the cross section of the log or take advice of an expert before cutting the wood so your strips do not warp after cutting. Ie you can only use certain sections of the log for your strips.
4. do not use an oily wood like teak or eucaliptus as you would have delamination of your epoxy sheething in the long run.
Hope you find the advice useful .
happy boat building
Regards
The Fiesta Yachts Team.( GOA )
Daren
Old 10-07-2004, 02:39 PM
nero nero is offline
Rep: 112 Posts: 624
Light Red Meranti
Light Red Meranti could work. It is about the same as WRC in specific gravity. It is lightly resitant to decay.
Below and near the WL you might be able to use Dark Red Meranti. It is harder, and more rot resistant.
hope this helps.
Old 10-10-2004, 12:13 AM
Rep: 10 Posts: 2
I have come across Meranti in India before but are not aware of the qualities. I shall do some digging and get back to the forum .
Ciao
Maneck
Old 10-11-2004, 09:03 AM
trimix trimix is offline
Rep: 10 Posts: 35
Originally Posted by jusembo
Hello,
David,
What can you tell me about catalpa ? do you have informations about its mechanical properties, resistances etc.. ?
Thanks
Trim
Old 10-12-2004, 08:22 AM
Rep: 2 Posts: 44
Katalpa
It's quite light (if you need i can weight the sample i have in thr factory and test resistance)
Big pores between the layers
Known, in China, as rot resistant
Cheap
David Jushpe
Guangdong China
www.solalelouna.com
www.morosof.com
Old 10-12-2004, 08:04 PM
julleras julleras is offline
Rep: 10 Posts: 16
Teak!
Tectona grandis is the cientific name for teak. I would suspect senior members would aprove this wood...
Juan M. Lleras
