Old 07-13-2009, 01:22 AM
matt76 matt76 is offline
Rep: 10 Posts: 29
looking for plans to build one of these
http://www.nigelirens.com/ldl/yachts...p?id=7&idcat=1
Old 07-13-2009, 02:12 AM
Willallison's Avatar
Willallison Willallison is online now
Rep: 2283 Posts: 3,468
You already found them.... what's wrong with talking to Nigel Irens?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 07-13-2009, 08:37 PM
Rep: 10 Posts: 29
something tells me he's not going to just hand over his CAD drawings of the hull. hell, maybe he would, i'll try it. looks a little like the sneak easy. just was wondering if anyone knew of any plans out there that would be close in design.
Old 07-13-2009, 08:45 PM
I wasn't suggesting that' he'd do it for nothing.....Nor would I...
It's nothing like the sneak easy, which is a simple flat-bottomed sharpie.
Iren's LDL series are all round chine, light displacement boats.
Will
www.imaginocean.net
Old 07-13-2009, 10:23 PM
Rep: 10 Posts: 29
i really like the performance ability of her hull design. i'm just a little garage cedar strip canoe builder. i want a bigger challange. i have the space and equipment to build the boat. the shop i use has an incredible CNC that could cut all the molds and anything else i need. the shop across the street from me has 2, five axis cnc mills that could mill the prop, shaft, ect. i just need the plans to a hull like that of the elektra. anything else out there that is close?
Old 07-13-2009, 10:50 PM
Rep: 10 Posts: 29
would you say the elektra is something like a fantail launch without the tail?
Old 07-14-2009, 12:45 AM
No!
What you really need to do is decide what you want this boat to be able to do. Then you can go about deciding which design suits your needs best.
I have sent you a private message
Will
www.imaginocean.net
Old 07-14-2009, 12:48 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Take the pictures to a local NA and ask hin to spec up 'one of these', That will cost you plenty also.
You are 'assuming' that the designer won't provide plans at a price you want to pay - you know what assuming does - makes and ASS out of U and ME
Contact him first - you might be pleasantly surprised.
Old 07-18-2009, 09:33 AM
dskira dskira is offline
Rep: 1305 Posts: 1,363
Send a check to Irens, and buy the plans. If you want some changes in the drawing, ask him and he will oblige. It is that simple.
Superbe design by the way. As usual with Irens, he is so talented.
Old 07-18-2009, 11:35 PM
Rep: 10 Posts: 29
i sent nigel a message and i'm waiting to hear what he has to say.
Old 07-19-2009, 06:38 AM
apex1
Originally Posted by Willallison View Post
No!
May I contribute here with a quote of Michael Kasten, adding that there are too many toads around the market?
One Day, A Little Round Toad Walked In...
Copyright 1996 - 2009 Michael Kasten
One day a little round toad walked into my office.
When this happened, what I actually perceived was that a very short human stood before me.
Was I hallucinating?
I put aside the drawings I had been working on, and listened while he spoke: “I’d like you to take a look at a fishing boat I’ve been considering. What I have in mind is to build one and market it as a small tuna boat, say around 45 feet. I have this one drawing that I like the looks of, but not the hull shape,” he continued. “And here’s another design that’s close to what I want, but isn’t big enough. It’s just not what I had in mind.”
I looked over the two drawings he produced. Both looked fine. He then asked, “Could you take the lines of this one and make it a little bit bigger? Can you model it with the computer so we can check out the stability and the carrying capacity?”
“Well sure,” I said, “that’s easy enough to do. The computer model will allow us to quickly derive a target range for the vertical center of gravity. We can work toward a final boat design from there. What sort of timing are we looking at?”
“I’d like to start building it in two weeks...”
There were several moments of silence.
It is possible to do a job like this in a very short time. Two weeks from a cold start, however, is pushing the envelope more than somewhat. Ordinarily, a boat design evolves over a period of time longer than two weeks. Two months may be pushing it. It does often involve choosing a few design examples as a place to begin, from which preferences are brought to light, and a new direction taken. It is not just time spent laboring over drawings and calculations, although there is plenty of that. Rather, it is time spent reflecting on the course the design is taking; what has been said; what has been drawn; what new ideas may come to light; what those new ideas will cost; whether the cost is justified; and finally, where to take the design from there. Time is simply required to pass. The drawings should be pinned to the wall for a while.
It takes a certain amount of tweaking for the elements of a good boat design to come together so that the boat will fully satisfy the wishes of her owner, and will meet the demands of the work she will be asked to perform. It is a complex task, perhaps seemingly awesome, but it is not difficult.
Rather than being a linear process, it is usually viewed as a spiral—the “design spiral.” The design moves around this spiral from Concept, to Specification, to Arrangement, to Hullform, to Sail Plan or Powering, to Construction Method, to Cost. One turn fully around, and the design is brought into greater focus. Looking again at the Concept, new judgments are made, another round of refinements are undertaken, and more detailed drawings are produced.
When finally a round is made, and no changes are required, the design is considered to be finished. The tangible result, the actual drawings, are the record of all those decisions.
The process can happen fairly swiftly, or it can span quite some time. It depends on the speed of the feedback / decision making loop for one, and in the real world, on the existing work-load faced by the designer.
If we view the many iterations required as being broken into roughly three or four “stages,” we would have, after the first round, the Napkin Sketch. Another turn of the wheel would bring the Preliminary Plans onto the table. While these preliminaries may represent a finished “Concept” they are not yet a buildable set of plans.
If all has gone well to that point, and the “Concept” is still on track, the Building Plans can be drawn. While there may in the end be several large blueprints, they represent only the “tip of the iceberg.” The number of calculations required to back up what has been created represents no small number of hours. They are not visible, yet in order to assure the success of the vessel, they must be done. Anyone who says differently is either trying to fool you, or himself. The point to be made is that, from the moment of the idea, the drawings are a process of discovery and refinement, rather than “final thought” etched on paper.
With all of these things in mind, I was now faced with a fellow asking if I could squeeze it into two weeks. I was at a complete loss to put a quick response into words.
“I can enter a set of lines into the computer, and have a look at a few load conditions within that time period, but it will not be a finished boat design.” Explaining much of the above to him, I finished by saying, “I really am quite busy just now. It will have to take its turn among the other projects I’ve already committed to.”
“Can you really do it?” he said as he left.
At the end of two weeks, having borrowed quite heavily from my other deadlines to make it happen, I turned over a preliminary set of lines and a preliminary stability study, using an assumed center of gravity.
The next day, the little man having had plenty of time to make a copy of my lines and preliminary report, he brought it back. “It’s just not what I had in mind,” he said. “It’s only a rough draft and a bunch of calculations. I can’t use this—I need to start building.” Then as he neared the door, “So I’ve decided not to pay for your work.”
I realized I’d been tricked. This time, I was not entirely at a loss for words. It is not clear to me just precisely what I then said, but I’m fairly certain it would have instantly burned the hair off any mere man.
There having been no such effect, I knew then that when he first walked in, I had been hallucinating. In the flash of an instant, he changed quite suddenly from prince to toad.
More recently, a fellow called from Indiana.
He said, “I have this boat design I’d like you to look at. I want to make some changes to it. What I want is a steel boat for ocean voyaging. I’m six feet tall. The boat has to have full standing headroom. It must be no longer than twenty feet.”
Right...
Why, you may have been wondering, is the Metal Boat Quarterly now two weeks late??
Michael Kasten
Metal Boat Quarterly #9 - Winter 1997 Editorial
Old 07-20-2009, 05:15 AM
The intent of Michael Kasten's piece is clear to me... yours, Apex1 is not...?
Will
www.imaginocean.net
Old 07-20-2009, 11:20 AM
apex1
If you (in context) remember that:
does it broaden your view? I just did´nt want to type it myself.
Richard
Old 07-20-2009, 11:51 AM
Alik's Avatar
Alik Alik is offline
Rep: 1020 Posts: 1,893
I got this email few days ago:
'I saw in the online forums you had 3d files for a mini650. I am beginning
designing now. Could you please send them to me when you get a chance?'
Surprised with such an impudence, I have asked why I have to send the drawings??? Maybe I missed something???
The reply was wonderful:
'You don't have to. I would appreciate it though if you did. I am starting my
design and would like a reference design to work from. Thanks'
P.S. This is exact text of what I have got, excluding sender's name. Both emails did not include anything like 'Dear Sir', 'Hello' or even 'Hi'...
Old 07-20-2009, 03:15 PM
apex1
Be proud Alik he has choosen YOU, and not any that came along! Tooo many fat toads..........................
Boat Build Plans: Where? pescaloco Fiberglass and Composite Boat Building 7 11-14-2008 08:04 PM
Looking for Farrier plans. Can change for Coral Sea 35 plans filiperosa Marketplace 0 01-06-2007 03:22 PM
Looking for Tiki 30 plans. Can change for Coral Sea 35 plans filiperosa Marketplace 2 12-29-2006 09:26 PM
plans to build a barge tbarton83 Boat Design 2 08-01-2006 02:18 PM
