Old 01-13-2008, 07:53 AM
RWD RWD is offline
RWD
Rep: 10 Posts: 4
Looking for Hull design
I am looking for a liveaboard houseboat design that is 45 - 50ft. with 12 - 14ft. beam. Will be used mainly for river and lakes but would like ICWW capability.
Low power twin outboard motors. Plywood - fiberglass construction. No thru hull fittings. Simple, low cost construction.
Looking for something along the old "Lazy Days houseboat High Bow Design", which was aluminum and I believe Jack Hargrave designed the hull. The actual cabin layout is not all that important (we can modify), but the hull design is what is needed.(in plywood)
Would apreciate any help.
THANKS
Old 01-13-2008, 11:16 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
The RYD-47 may be a bit fancier than you're looking for, but damned gorgeous - http://www.boatdesign.net/gallery/sh...94/ppuser/2040 - her creator goes by the handle "PAR" on here if you're interested.
Something a little less pretty and a little smaller, Glen-L's 45' "Bon Voyage", https://www.boatdesigns.com/products.asp?dept=165 - multiple construction method options, designed for one-off home build.
Is this the "Lazy Days" boat you mention, http://www.pnb.yachtworld.com/core/r...222454&isPLS=0 ?
Old 01-13-2008, 02:38 PM
RWD RWD is offline
RWD
Rep: 10 Posts: 4
Matt -
The Lazy Days boat in the link does have the high bow hull that I am looking for in a plywood design. The draft on that hull is only 18". I would like for the cabin sole to be the bottom of the hull. The boat in the link is built with a higher main level profile because it is totally above the hull top. The total hull height is about 36" +/- on the Lazy Days. PARs design is pretty but the redesign for outboards and no 2nd level would be a lot of redesign.
Would be interested in just a hull design if a designer understands my goal.
THANKS
Old 01-13-2008, 04:30 PM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
http://euler.sfasu.edu/Shantyboats/
Pericles
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 12-31-2005 11:40 PM
hull design / furniture design bogeyinthekeys Software 10 09-18-2005 07:16 AM
Hull Design Magsls1 Fiberglass and Composite Boat Building 1 08-19-2004 08:21 AM
Hull Design Pierre Badin Sailboats 21 07-23-2004 05:06 AM
hull design Guest Boatbuilding 2 09-18-2003 06:39 AM
