| looking to build a boat need some help hey all im looking to build a boat i was looking at building one out of foam by first building a mold that i could pour the foam into and letting it rise and cure my problem is what would the best way to do this and if any of you have ever tried this i have also thought about covering the foam with some sort of plastic coating or fiberglass does anyone have any suggestions on how to do this or even would this work |
| You first build a boat to take the mold off. If you are building only one, it doesn't pay. It is easier, faster and cheaper to cut a block of foam into the final shape.
__________________ Gonzo |
| the design of boat i am looking to build is flat bottom v nose style row boat that could have an optional 5 to 10 horsepower motor if i was to cut it out of a block of foam what would be the best way to cut the interior out |
| It would be much easier to "stitch" some sheet foam into the shape you desire, then 'glass both sides. I hope you have a set of plans . . . |
| Can you build a boat this way? | Dreed | Fiberglass and Composite Boat Building | 11 | 02-18-2006 02:58 PM |
| Which Wooden Boat Should I Build | Rileystargate | Open Discussion: All Things Boats & Boating | 1 | 09-24-2004 09:26 AM |
| Looking for a small boat to build | aquarius | Boat Design | 2 | 01-20-2004 03:39 PM |
| why not build your boat in Namibia | ongolo | Services & Employment | 10 | 10-26-2003 11:41 PM |
| Build a boat in Brazil | Brazil Boats | Services & Employment | 3 | 06-27-2003 12:54 PM |
