#31
Chad, I understand that you're trying to use the glass and epoxy you already have to make up for such thin plywood, but I dislike the use of thick glass with thin plywood because the end result is that for the same overall thickness the 'thick ply / thin glass' approach is always stronger and stiffer and lighter -- and these are all features you should be striving for when you build a boat like the one you're talking about. Besides, if you're going to use as much glass as you're talking about anyways I have to wonder why you don't use 'just a little more' and get rid of the plywood completely? Then at least you'll end up with a boat that's never going to rot. Quote:
-------------- Here's my take on this situation: I have suggested what I feel is the most effective and affordable way for you to fix your existing boat. It is no big deal to me if you don't want to fix it, and it is fine if you want to build a new boat too. These decisions are entirely yours to make! However ... Several of us have also suggested (more than once) that if you're going to build a new boat you should buy the plans from a designer and build your new boat according to those plans. There are many good reason for this, but you seem determined to forge ahead with your own approach. That's fine too of course since you are welcome to do things however you want to do them. On the other hand, I can imagine all kinds of problems with this approach -- problems that I'm not interested in trying to help you solve because I've already provided what I feel is my best advice. If you turn this thread into your 'building blog' I may check in from time to time to see how you're doing. I actually enjoy seeing people do things differently from me because there's always something new to learn when you keep an open mind. I wish you the best of luck no matter how you proceed! ![]()
__________________ Kenneth Grome |
#32
| hey i can help ya contact me and i will show you what i have im currentl just made a new boat flat bottom with lift pad 15 ft so on if interested lets talk.. i have pics..its also stronger and cheaper to use 3/4 ply wood on floor you will use to much glaas in strenghth versus wood and is cheaper to just put in the wood and lay a matt and weave over it!!and lighter...here are some pics.. and i will sell this boat plain no rigging or the hull only from 1300 to 3200 dollars |
#33
| pictures of the boat in build progress. Any finishing suggestions is greatly appreciated. Chad ![]() ![]() |
#34
| Another side view... ![]() |
| Where would you build a boat in the UK? | mattnedgus | Open Discussion: All Things Boats & Boating | 30 | 09-18-2007 06:30 AM |
| Build my first boat | mirsat | Fiberglass and Composite Boat Building | 3 | 08-27-2007 08:23 AM |
| Help me to Build a Boat | sharkfish | Boat Design | 6 | 05-31-2007 05:22 PM |
| looking to build a boat need some help | Bryan Campbell | Boat Design | 3 | 02-24-2006 08:20 PM |
| Can you build a boat this way? | Dreed | Fiberglass and Composite Boat Building | 11 | 02-18-2006 01:58 PM |
