Old 07-14-2010, 12:14 PM
hannapiana hannapiana is offline
Rep: 10 Posts: 3
Log raft design
Hi everyone
I'm totally new to this and need to ask what is probably a very simple question about building a log raft
I'm building a log raft for an art project. It only has to carry me (I weigh 55kgs). I'm currently in the Finnish forest and the only logs I can manage are quite short (about 1.5m). All of the designs I've looked at online say that the main logs should be long, with two shorter logs holding them together. Is it possible to do it the other way around, so the shorter logs make up the raft, and the longer logs hold it together? Or would this make it harder to float?
Thanks everyone!
Cheers
Old 07-15-2010, 12:27 AM
uncookedlentil uncookedlentil is offline
Rep: 8 Posts: 81
Build it with two long logs with enough flotation to support your weight and the required 1.5 decking clear of the water and you'll have a neanderthal dream come true, the Dawn Catamaran!
Old 07-15-2010, 01:34 AM
Rep: 10 Posts: 3
Thanks for your help!
Old 07-15-2010, 06:39 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
You can do as you suggested, it's just more resistance and harder to pole ahead.. The hard part in log rafts is to bind the structure together in a way that holds reliably..
BR Teddy
Old 07-15-2010, 07:02 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
What a bunch of artless yahoos!
I suggest you use short logs to build a dodecahedron structure and then stand inside it. Naked. Then you can tumble across the surface of the water while doing something arty. With a fish.
Leo.
Old 07-15-2010, 07:13 AM
Rep: 10 Posts: 3
All great suggestions
Thanks everyone!
Old 07-15-2010, 11:14 AM
TeddyDiver's Avatar
Gollywobbler
Always a pleasure to help a lady And surely want to see if you'll realize Leo's suggestion
Raft/Junk Raft Building djwkd Wiki 5 03-03-2011 10:47 PM
Raft Design Wagganet Boat Design 4 12-16-2008 02:41 PM
Collapsible raft design, Help! Pipsta Boatbuilding 7 06-22-2007 11:25 AM
Making a log raft paffka Boat Design 6 03-31-2007 04:16 PM
3rd log on pontoon Bowtie41 Boat Design 0 07-12-2006 11:34 PM
