Old 03-17-2010, 01:47 PM
longfellow longfellow is offline
Rep: 17 Posts: 35
Lofting question
I have a simple Vee bottom daysailer with the easiest hull to plank (developable surfaces and a chine that meets the front of teh keel at teh base of the stem. Offset table is complete but the typical locations above LWL and forward of Station one which give the very front of the rabbet at both the top and bottom of the stem, are not there. This is not uncommon, particularly with the designer and date in time in his career when he designed boats. Water under the bridge.
My approach, which I'd like your concurrence or comment on would be;
Complete the plan with chine and sheer lines. Fair them to teh halfbreadth of the stem which I do have (typical 1/4 inch for a 1/2 inch brass hlf oval at teh stem face).
Use these two points fwd of station one tocomplete the profile and HOPE THAT THE KEEL BOTTOM AND SHEER LOOK FAIR !!!
Hopefully I haven't deviated too much and introduced any difficult twist in either the side or bottom planks as I may decide to swap out the solid planks for plywood and I know about the rules for bending plywood.
I can't think of any other way to complete these lines.
Old 03-17-2010, 02:54 PM
Rep: 1493 Posts: 7,447
If you are planking with plywood, it doesn't make much sense to make a rabbet. Plank to the stem, and then glue or laminate on a false stem. It is way easier and faster.
Old 03-17-2010, 02:58 PM
Rep: 1758 Posts: 1,561
Is there a rabbet shown on the stem? I mean, this sounds like there would be no exposed stem, but a false one.
http://freepages.genealogy.rootsweb..../cranks/09.gif
http://freepages.genealogy.rootsweb..../cranks/03.gif
Edit; Gonzo beat me to it.
Old 03-17-2010, 03:00 PM
If a batten lays fair, it should be easy to plank. Use a batten of the same or more thickness than the planking.
Lofting CD set- Lofting with Arno Day longfellow Marketplace 0 04-24-2009 09:51 AM
Lofting??? Winingar Wooden Boat Building and Restoration 2 07-04-2007 04:35 AM
Lofting elcapitan Boatbuilding 7 04-20-2007 06:37 PM
Lofting LBG Metal Boat Building 7 05-28-2005 09:26 PM
Lofting with CAD2000 JOFRACON Wooden Boat Building and Restoration 1 04-25-2004 02:03 PM
