| Loading Cycles on Submarine Hi everybody! I want to ask that what is loading cycles on a submarine?Can anybody refer me some documents? Regards, Thanx |
| Dock the Sub, walk to the dock, pick up your package, walk back to the sub, load package. K9 |
| The load cycles of (military) submarines are actually quite low: 10^4...4*10^4 Admittedly I have only very few documents or literature about submarines. I guess you are familiar with "Submarine Design" by Ulrich Gabler (published by Bernard U. Graefe, ISBN 3-7637-6202-7)? Quite a good paper is "Some Aspects of Submarine Design" by Prof. P. N. Joubert of Australia's Defence Science and Technology Organisation (DSTO), consisting of Part 1: Hydrodynamics and Part 2: Shape of a Submarine 2026. The DSTO publications are generally an excellent source. Additionally, I have a well-written university hand-out which however is in German. If you can read German (since you are located "anywhere" there is a good chance that you can ) just PM me your e-mail address and I'll send it to you.
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| "Theory of Submarine Design" by Professor Yuri N. Kormilitsin and Professor Oleg A. Khalizev from the Saint-Petesburg State Maritime Technical University. Published in English and printed in England in 2001. 328 pages of highly technical work by two leading designer in submarine. Yuri Kormilitsin use to work at Rubin as a General Designer. |
| Sir, unfortunately I cant understand German otherwise it would have been quite beneficial.Can somebody provide me in English or is there anyway I can get a translated version of this and/or the other mentioned handouts?? |
| Sorry, but the hand-out was written by a prof of mine and so there's only the German version available. The paper is 85 pages so a translation of the entire text unfortunately would be too time-consuming for me at the moment. However, if there's a certain topic you're interested in I could do a quick translation of the relevant part/chapter. Edit: Contents of the hand-out 1. Introduction 1.1. Scope of this lecture 1.2. Characteristics of submarines 1.3. Development of military submarines 1.4. Development of civilian submarines 2. Hydrostatics of submarines 2.1. Weight situation 2.2. Weight and trim adjustment 2.3. Stability 3. Hydrodynamics of submarines 3.1. Hullform 3.2. Resistance and propulsion 3.3. Manoeuvring characteristics 3.4. Model tests and trials 4. Hull 4.1. Loads on the hull 4.2. Pressure hull: Strength, stability 4.3. Non-pressure resistant areas of the hull 4.4. Materials, welding 5. Propulsion plants, energy generation 5.1. Introduction 5.2. Battery operation 5.3. Diesel-electric operation 5.4. Fuel cell propulsion (AIP) 5.5. Closed-circle diesel engine (AIP) 5.6. Stirling engine (AIP) 5.7. Closed-circle gas turbine (AIP) 5.8. Steam turbine (AIP) 5.9. Nuclear reactor (AIP) 5.10. Other propulsion systems 6. Safety and rescue facilities 6.1. Safety philosophies 6.2. Safety facilities 6.3. Rescue facilities 7. Equipment and accomodation 7.1. Breathable air management 7.2. Equipment 7.3. Facilities for the crew 7.4. Control facilities 8. Sensors / signatures of submarines 8.1. Signatures 8.2. Sensors 9. Construction, quality management and sea trials 9.1. Construction of submarines 9.2. Quality management measures 9.3. Documentation 9.4. Sea trials
| I want to know the basic concept about loading cycles? is there any procedure to predict loading cycles? |
| You can buy an article on the matter here: http://cat.inist.fr/?aModele=afficheN&cpsidt=1305070 An article on fatigue cracks, cycles and the Paris equation here: http://steel.keytometals.com/Articles/Art49.htm Basics about fatigue: http://en.wikipedia.org/wiki/Fatigue_(material) Fatigue crack initiation: http://www.ndt-ed.org/EducationResou...re/fatigue.htm Cheers.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| I am interested in Chapter 4 which is related to hull part of your document.It will be quite nice if you can send me the english version of it. |
| Ama, Tell us the question you are looking to have answered, and we will be better able to point you in the correct direction. There is very little out there available to the amateur on hull design. Try to get copies of Manned Submersibles (1976 ed) by Busby; and Submersible Vehicle Systems Design (1990 ed), PNA (the 1967 single volume ed), SD&C (the 1969 ed) all by SNAME. From a pressure loading cycle point of view, there are two seperate and distinct considerations over the life of a submarine/submersible. High load-low cycle loads and Low load-high cycle loads. The first, as Olav mentioned, is based upon dive cycles and is measured in the low thousands for submarines and the hunderds for submersibles. It mainly effects material and fabrication requirements. The second is based upon the seaway, and is measured in the 10's of millions for submarines and low millions for submersibles, and is a concern of the fatigue life of the hull material. No material is best suited for these two different criteria given the other operational criteria (i.e. depth, shock, size, etc.)
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-13-2009 at 12:06 PM. Reason: billion is too big |
Wave cycles are a little different, they are based upon a significant wave period (i.e a wave which causes flexture stress to excede a certian threshold) over the entire life of the vessel as long as it is afloat. Using the above 20 year life example with a 10 second significant wave. (20)*(365.25*24*60*6)=63 million
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-13-2009 at 12:24 PM. Reason: typo |
| I am looking to learn the basics about the loading cycles.how to use them to predict the life of different materials?how to use these loading cycles in numerical simulations in order to predict and understand their effects. |
PS, That sounded a little harsh, so I apologize. What I mean is that while Naval Architecture can give you the loads and cycles a particular structure will see, the actual data of material strength, flexture-limits, crack growth propensity, etc are handled in the materials lab and are not directly addressable by hydrodynamic/hydrostatic simulations. You chose a material based upon your desired properties and tune the structure to the materials limits, not the other way around becuase it is too difficult to tune a material to get the desired properties. CF structures are a prime example, as little as 2 degrees off axis fiber orientation can cause a 20% reduction in material strength so you must accept lower loads than you could calculate.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-13-2009 at 12:03 PM. Reason: PS |
| Bu How to predict the loads?What all things need to be taken care of? |
The design of hull fittings is a whole other matter though, but can be handled seperatly from the actual pressure hull.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 07:19 PM |
| Mast Loading | kenJ | Sailboats | 2 | 07-01-2008 07:14 PM |
| Sail Loading of Rigging | Inquisitor | Boat Design | 3 | 11-14-2005 09:58 AM |
| Engine loading | operator | Boat Design | 8 | 04-25-2005 05:07 PM |
| Bottom Loading | Willallison | Option One | 3 | 06-04-2002 09:03 AM |
