Old 10-09-2011, 08:33 PM
Laranjo123's Avatar
Laranjo123 Laranjo123 is offline
Naval Architect/Engr. FG
Rep: 17 Posts: 128
Load waterline curve?
I have a question is loadwaterline curve important in designing the hull? Because when i use maxsurf i only see the graph of sectional area curve. isn't that LWL curve should be with SA Curve . They should be together in one sheet?
Old 10-09-2011, 10:32 PM
Rep: 749 Posts: 1,314
Section area curve is not the same as waterline curve. SA merely describes the distribution of area of successive stations. Waterline curve is the path that a particle would trace if it ran along the surface of the hull. Waterline curves may be the ones that describe the particle path at the surface of the water or at any other selected underwater path along the length of the boat. Think of them as horizontal bread slices. Waterlines are usually shown on a plan view of the hull and there may be more than one of them depending on the shape of the sections.
Gennaker bowsprit load nemo Boat Design 7 09-12-2011 07:28 AM
Gennaker bowsprit load nemo Sailboats 1 09-08-2011 12:57 PM
...summer load waterline... fradrigo Boat Design 4 12-22-2006 07:44 AM
keel load, dynamics water addict Boat Design 0 02-28-2005 11:05 AM
mast load nemo Sailboats 13 08-21-2003 08:14 PM
