Old 09-15-2007, 04:06 AM
corsair.p corsair.p is offline
N.A.China
Rep: 10 Posts: 20
Little RIB performance.
Hi,gentlemen,
We have troubles in testing our 12' RIB,the boat has too big trim angle when starting to planing.And even bad,when it's planing,always have porpoise movement make it very uncomfortable for people.
We are thinking to add one more sprayrails each side(currently only have one) and add an outboard stabilizer on the 50hp OB to test again.
But i am not sure it's gonna work,so if someone can give some idea to solve the problems we will very appriciate.
Or maybe someone can tell me where i can find some technical informations to study?
Thanks
David
Old 09-15-2007, 08:30 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
What horsepower is the boat rated for...50 hp seems way to high.
Steve
Old 09-15-2007, 10:59 AM
N.A.China
Rep: 10 Posts: 20
we just test the boat at it's Maxium Power as calculated from ISO standard.And it's 50hp.
Old 09-15-2007, 05:57 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
I believe your problem is that the boat is way overpowered and thus way off balance.
For comparison purposes, Zodiac's 340 DL and 380 DL (11'2" and 12'6" respectively) are rated for no more than 30 hp and 40 hp respectively; Zodiac advises against using more than 30 on either.
A 50 hp outboard weighs about 100-120 kg. There will be a person sitting right in front of it, another 80 kg. So you have as much as 180-200 kg at the transom in a boat that is only twelve feet long. Couple that with a lot of thrust from a propeller down below the bottom and you have a recipe for excessive bowrise.
I have two suggestions before you start gluing strakes and foils onto the thing.
(1) Recheck the maximum power calculations.
(2) Replace the 50 with a 30, move the crew forward a bit, and try again.
Old 09-17-2007, 10:03 AM
N.A.China
Rep: 10 Posts: 20
Thanks,matt.We will try..
Why not RIB? Nojjan Boat Design 12 09-01-2007 02:16 AM
LCG in RIB Mat-C Powerboats 3 07-10-2007 02:50 AM
New Rib grp.boat Boat Design 5 11-25-2006 02:28 PM
RIB - 6.5 m Bijit Sarkar Boat Design 4 06-26-2006 03:14 AM
rib help billboat10 Powerboats 1 05-16-2004 12:42 AM
