  #31
Old 06-27-2008, 05:28 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by dtoshni View Post
Dear Rick,
I am using this formula to calculate the Reynolds number. Is this correct?
Rey. Num. = density*velocity*chord length/abs. viscosity
Daniel
Yes.
I use 0.0013Pa-s for the viscosity. I think this is around 10C.
You might want to make the foils a little longer as the Re# is quite low if your speed is only 0.6m/s. The L/D will improve as the Re# goes up.
It would help if you provide some picture of what you have and drawings of the intended fins.
Rick W.
  #32
Old 06-27-2008, 08:23 AM
dtoshni dtoshni is offline
Rep: 10 Posts: 40
Ok..thanks Rick.
And one more thing Rick. I was just playing with the values in JavaFoil. I found one interesting thing with the airfoil cross section NACA 2410. When the angle of attack reaches 90 degrees, JavaFoil shows a Cl = .023 and Cd = 25 !!
Is this correct? Can the Cd reach such high values? I thought the maximum was that of a flat plate, with Cd = 2.
Daniel
  #33
Old 06-27-2008, 09:13 AM
Rep: 10 Posts: 40
Also Rick I wanted to ask you, What happenes to a NACA 2410 foil if the angle of attack is 180 degrees? I know the lift coefficient will be negative. But does that mean the lift will be upwards or downwards on the foil?
  #34
Old 06-27-2008, 06:12 PM
Previous Member
Rep: 0 Posts: 0
I would be skeptical of results from extreme cases in JavaFoil. I expect the theory breaks down. I normally work inside the bounds of stall and not interested in data outside.
If you need to go backwards then the best solution may be a cambered plate foil. These have a narrow range of operation but will work as effectively in either direction. Maybe nothing more than a flat plate set at a slight angle. You just need to keep them thin relative to cord. Very simple solution.
  #35
Old 06-28-2008, 12:39 AM
Rep: 10 Posts: 40
Hmm.. Thanks Rick I'll think about it.
light weight lay up nordvindcrew Fiberglass and Composite Boat Building 22 09-18-2007 07:48 AM
DIY Diving fins Lovre Fiberglass and Composite Boat Building 21 04-30-2007 11:48 AM
i need help TO design me DIVING BOAT world Diver Boat Design 20 03-18-2006 02:46 PM
design for diving boat drives cyprianoo Propulsion 1 10-02-2005 09:04 AM
Portager's Light Weight Engine Portager Boat Design 0 07-22-2003 01:57 AM
