Thanks for your assistance guys. Quote:
Originally Posted by Commuter Boats I apologize, I posted in a hurry and didn't reread what I typed. What I intended to suggest was plywood, epoxy and fiberglass could be used, high density foam would be a plus but there was no need for plugs.
I believe that counter sinking plywood deep enough for plugs is not a good idea. |
I read your original version with the same meaning as your revised message. We must be of the same mind set.
Originally Posted by PAR I do believe if the after half of each hull is squared off, there will be enough plane surface. Then the question will be; is there enough power. A buddy with a 22' fully dressed pontoon boat does moderately well with a 90 HP Honda, but at half the weigh of this boat. Using the same multiplier and doubling the weight I get 14.5 knots (17 MPH) which is up on plane a scooting along at over S/L 3.1. Not exciting, but respectable and you will not make a career out of crossing a lake. |
I am going to attempt to square off the after hulls as suggested. I do expect to have the strakes put her over 20 MPH. I was clocked by a friend at just under 19. At that time, my rebuilt motor had only about 2 hours on it, there were 4 adults on board and the trim pistons were not holding the engine at all. The flattened tail should help.
Yellow Jacket - Thanks for the link.
