Old 10-04-2002, 07:20 AM
DavidG DavidG is offline
Rep: 60 Posts: 52
Lifting Lines
I would be interested if any of you have any experience of lifting lines of existing boats.
I am interested in finding a cost effective approach, so that I can input data into a NA package to calculate stability.
There are three approaches that I can think of;
1, Using chains and direct measurements, transfering these full size onto doors for various sections (we did this as a project at S'ton Institute) and measuring off. This is labour intensive and not very accurate.
2, Photographic methods (there was a paper in this in the Naval Architect some years ago). The essence of this was to photograph the boat at various predefined angles, with a calibrated stick at the station, and apply scaling and trig.
3, Laser/digital technology, I have seen info on measuring systems used in Formula 1 and quality inspection systems, these look very expensive and beyond the buget of this naval architect.
Any other ideas, refinments or references would be appreciated.
Many thanks,
David
Old 10-04-2002, 05:08 PM
I have been looking at digital laser measuring devices here in the UK and reckon I might buy one for taking lines. They're only £25.
Set up a vertical staff on the station line with a couple of nails as datum points - one high, one low on the staff. Pick off a point on the hull from the high datum with the laser, mark it with a pencil and record the distance. Pick off same mark from the lower datum and record distance. Drawing out the body plan in Autocad will be quite quick and then you can make a table of offsets (or whatever your stability programme needs).
Old 10-04-2002, 11:11 PM
MDV MDV is offline
Rep: 60 Posts: 31
You can do it cheaply by using string lines, plump bob, sprit level and a measure tape. Just set up the horizontal string lines along the CL and at the required sections, and with the plumb bob and measure tape you can get the X & Y offsets at those sections. For at least one section you should measure both port and starboard to be able to adjust for the heel. With some practise and patience this is a fast and accurate method.
As a source for other methods, I suggest to contact your local measurer for ISM etc. they must have a fast and reliable method.
Regards,
Michael
Old 05-28-2003, 05:29 PM
kudu kudu is offline
Rep: 10 Posts: 112
Lifting Lines
Greetings...You might want to check out the August 2002 #167 issue of WoodenBoat magazine. On pages 34-39 you will find an awesome explanation of the subject you are interested in. Enjoy!!!
Old 11-22-2003, 02:42 PM
I worked at a naval architecture firm last summer and we hired surveyors to lift lines using laser theadolites (?sp)... It cost about $500-1000 and we got a point cloud (~1000pts), then import them into rhino and fit a patch to them... It's involved however you do it, but I'm pretty keen on the theadolite method... I think there's a real art to the chains/measuring devices, they probably work well also... It just might take some time getting things laid out...
I think you can rent theadolites for $100-200/day... I guess I get excited about the technology of it... It depends on the application really... if you're doing something for a client who wants exact information on what they have I'd go with the theadolite, while if you're just trying to design something 'similar' manual methods might suffice... Of course it also depends on the size of the project... over 50', I'd imagine that the manual methods get quite difficult...
fireball682@hotmail.com
Old 11-22-2003, 03:14 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
I think it can be done using www.photomodeler.com if you project a grid on the side of the hull and take photos from 2 known points. There might be more info on this at www.touchcad.com or www.eossystems.com
If you want to make a quick cast of a small boat or a portion of a hull check out www.runliteusa.com/products.htm
A warning: splashing the lines of a hull and building it without legal rights has become prosecutable, and the lawyers are waiting for a nice juicy test case! See the "Parting Shot" at the back of a recent Professional BoatBuilder magazine.
Old 11-22-2003, 08:07 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
wow, all very interesting and gettin better all the time.
now how do i get 8 day's in a week?
yipster
Old 11-22-2003, 09:02 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Measuring a hull
Measuring odd shapes,
I think you have a grasp of what is out there. The threads above are what I know about the subject. I like the Faro stuff.
Gary
Old 01-01-2004, 03:40 PM
yipster's Avatar
5 weeks back i asked for a demo CD, but like to learn more!
this photogrammetry system may be of great help and as long as its for measuring, background stuff etc i guess its as free as taking a normal photo?
i understood the simplest system uses ordinary digital camera input from varied angles without laser or target dot references, and then builds a wireframe? wow, this can be time saving! wondering what i get, if i can easely get it to work, what formats are supported and more i'm downloading a demo now...
Old 01-01-2004, 11:00 PM
Rep: 1493 Posts: 7,447
The first method is very accurate if done properly. A variation of it is shown in Dave Gerr's "The Propeller Handbook". He uses it for a quick displacement method, but can be use for stability as well. With the new laser levels the manual method can be used with advantage. The whole mess of leveling strings or boards is largely avoided. These levels sell for U$39.00 and are accurate to 1/8" in 30'.
lifting keel mechanisms- hydraulics? water addict Sailboats 16 01-01-2006 11:16 AM
Water lines to headers on a 454. How to hook them up? 21 Hawaiian Powerboats 8 06-03-2005 01:03 PM
Influence of wind gradient on lifting line nico Sailboats 1 12-04-2004 02:04 PM
Help with Fatty Knees Lines Builder Boat Design 2 08-01-2004 05:45 PM
line drawings kudu Boat Design 5 01-30-2003 12:51 AM
