Old 06-12-2006, 10:35 AM
Robin Walker Robin Walker is offline
Launch for coaching rowers (Crew)
I am a rowing coaqch in the UK and am in search of the ultimate design for a coaching launch. The spec should fulfil the following criteria:
  • Minimal wake at speeds up to 10 knots – a racing eight travels at about 20 Km/hr, but most training boats travel at much less. Inflatables we have tried in the past push a lot of wake at low speeds, though this reduces on ‘the plane’.
  • Reliable
  • Economical
  • idiot proof – most rowing coaches have their minds on their crews, and only notice the launch if it goes wrong
  • Easy to get on and off the water from a landing stage (pontoon)
  • Steered by wheel, not tiller steered (had some scary moments with tiller steered launches on the Thames)
  • Capable of carrying up to 5 rescued rowers to safety.
Any suggestions?
Old 06-12-2006, 04:39 PM
dougfrolich dougfrolich is offline
Rep: 178 Posts: 567
why don't you make a catamaran out of 2 older training boats. joined by aluminum sections with a plywood platform on top?
Old 06-12-2006, 06:12 PM
SeaSpark SeaSpark is offline
Rep: 96 Posts: 593
Hm.. nice idea, have my questions about manoeuvrability of such a craft though. And even training boats are very light in construction.
Hm.. with a tiller you can move you rudder from port to starboard in a smaller instance then with a wheel. Suppose the wheel steered boats you are using steer an outboard engine instead of a rudder.
Old 06-12-2006, 07:00 PM
JPC JPC is offline
Rep: 20 Posts: 90
As a former coach, I've wrestled with the same issues. There are catamaran launches made that are quite popolar. I think that Pocock makes one (Seattle) and that there's another model made by some of the fellows at the Sacramento State University Aquatic Center. (I've done a quick look for links for this, but haven't found the launch - if I do, I'll re post) -these have been advertised in the USRowing magazine, so if you've got access to any issues you might find it there.
The catamaran is very stable (rescue) and low wake. A drawback, however, is that they are quite wide and it can be more difficult to nuzzle up to a shell between two oars for swapping oarsmen or doing a fix.
I've seen some cathedral hull shapes used in coach launches that were a good compromise.
-JPC
Launch Design fhrussell Powerboats 8 11-23-2005 07:18 AM
Why move crew to the bow going down wind? Cliff Ruckstuhl Sailboats 5 09-21-2005 01:55 AM
Awlgrip painting/fairing crew required DGreenwood Services & Employment 6 06-21-2005 11:49 AM
3 Captains, 1 crew Willallison Open Discussion: All Things Boats & Boating 11 02-06-2005 09:31 PM
Open 50 Crew numbers Danger Mouse Boat Design 2 10-15-2004 11:15 AM
