| That last 10% of efficiency. This should probably go under a previous post. I've been told a couple times now that I shouldn't worry too much about some design element, such as LCB forward or aft of middle, because it only makes a small difference in efficiency. My resposnse is this: imagine you are on a canoe trip. You've been paddling all day. It is getting late. You are tired, hungry and can't seem to find a good campsite. Do you think I don't care about that last 10% of efficiency? I've been in that spot on more than one occasion. Every percent of efficiency counts when you are the motor. |
| Numbers in my comment may have been incorrect so I deleted it.
__________________ David Cockey |
| You make it sound like a military exercise. Where's the enjoyment in fretting over a minor difference in your progress ? Stop and smell the water lilies. ![]() |
| Fine entry and exits, the sharper the better. Long and skinny is faster. Round bottom is the least wetted surface. Asymmetrical shape is fastest, I read ages ago that reverse asymmetrical, with the fatter part forward, was faster than the opposite and was even not allowed in class racing. You might look outside the box, as in other than the shape of the canoe. A smooth (no scratches, gouges) bottom freshly waxed can be a few percent. A lightweight skin that flexes is inefficient, as you lose an efficient shape. Better paddles can add 10% or more efficiency. Carrying less weight and stowing for best trim can also help. Try only going on free flowing rivers and forget the paddling. ![]() |
| It would be very very much harder to find the last % of efficiency within the constraints you have decided for yourself than to gain efficiency by changing a bit your self decided constaints. For your example, if you want an efficient canoe, instead of finding the optimal LCB for the loading and power the padller will have (NB you can find an optimal LCB, but it will depend on speed and loading) , just add length to the canoe, or try to lighten it. |
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| jehardiman and other have provided good advice good advice. (A re-write of my earlier, now deleted, post.) Be aware that at typical canoeing speeds (not sprint racing) viscous drag accounts for 80% or more of the total drag. A change of a couple of percent in LCB location will change the wave drag by a couple of percent or less, and have virtually no direct effect on viscous drag. The net effect on total drag will be less than a percent. (That's assuming LCB was in a reasonable location to begin with, and the hull form is not extreme, and no "tricks" were used to change the measure LCB location.) On the other hand a change of wetted surface area translate an equal change in viscous drag, which at canoeing speeds will be seen as an almost equivalent change in overall drag. So worry about wetted surface area first. Also, in use the LCB will be located where the CG of the boat, occupants and other contents is. That is simple hydrostatics. Even a symmetric hull can have LCB forward or aft of the center of the boat depending on where the occupant(s) is/are located and how the boat is loaded. Back to optimizing LCB location for minimum drag. The "optimum" location for minimum drag depends on the speed. So do you want to optimize for when you are trying to get maximum speed for a short time (further aft) or for slower speed, long distance cruising (not so far aft)?
| Diesel Efficiency vs. Gas Efficiency | Northwester | Diesel Engines | 23 | 02-14-2009 03:49 PM |
| Prop efficiency? | MagicMike | Outboards | 7 | 10-02-2006 07:49 AM |
| Hull Efficiency | Amador | Propulsion | 17 | 09-21-2006 03:43 PM |
| Fuel Efficiency | john.G | Boat Design | 1 | 06-22-2006 03:05 PM |
| Propeller Efficiency | fredrosse | Boat Design | 3 | 03-16-2005 08:10 PM |
