Old 07-25-2007, 12:45 PM
fastwave fastwave is online now
Rep: 36 Posts: 72
Laser cutting MDF
Hello guys,
Does anybody know a good place to laser cur MDF frames for a plug? I have searched the forum and found a couple of places. Also any company that has a large table 4x2m or bigger?
Anywhere in Europe will do.
Thanks for your help.
Old 07-26-2007, 07:01 AM
Greybarn Greybarn is offline
Rep: 10 Posts: 57
A CNC router for cutting MDF will be better. We have used a Laser to cut plywood which worked well but we routinely use CNC routers for that purpose. Unfortunately, we are in North America and don't know anyone in Europe
Old 07-26-2007, 07:41 PM
Rep: 36 Posts: 72
I was under the impression that laser cutting was cheaper because it is faster. I could be wrong, but would be good to know for the future since it is proving a bit difficult to get anyone with suitable laser cutter.
Thank you
Old 07-27-2007, 07:09 AM
Rep: 10 Posts: 57
Cutting MDF with a router is like a hot knife through butter. I would go the CNC router path.
Old 09-18-2007, 01:18 PM
Rep: 36 Posts: 72
Just to complete the thread. I got the frames laser cut. There was no price difference between router and laser for 18mm thickness. Laser gives you more options with regards to internal corners.
The other thing is that 8x4ft was the maximum I could find. The problem was not the laser table size but the actual mdf supply.
Hope it is usefull
Old 09-18-2007, 04:35 PM
grp.boat grp.boat is offline
Rep: 10 Posts: 46
We regular use 10 x 4 mdf... Where did you get it laser cut?
Old 09-19-2007, 03:34 AM
Rep: 36 Posts: 72
It was in the UK. I asked many companies and they all said the same pretty much.
R/c Laser Yacht Wanted Glowman Sailboats 2 12-14-2006 06:18 PM
Repairing a laser the_sphincter Fiberglass and Composite Boat Building 7 01-24-2006 08:14 AM
MDF female molds for autoclave? marshmat Fiberglass and Composite Boat Building 6 10-30-2005 07:38 AM
Has any one used MDF to build with ? Trout Slayer Wooden Boat Building and Restoration 7 11-28-2004 11:42 PM
Need LASER 1 3D model for my thesis Tomas atria Boat Design 0 02-06-2004 01:43 PM
