Larson Million Bubble ride from 60's
Discussion in 'Boat Design' started by DFAIRCLOTH, Mar 9, 2014.
  1. DFAIRCLOTH
    DFAIRCLOTH New Member
    Anybody familiar with these hulls and how they perform? I have a 1960 Larson Sea Lion 178 which is a cool looking and well built retro hull. One performance report has a 1961 merc 80 pushing it about 36 mph. Since that is probably about 65-70 hp today that seems pretty good and fully loaded it ran about 32.
    Any info would be helpful
  2. gonzo
    Likes: 1,714, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    Mercury was notorious for underrating the power. 80 might have been 85 HP. Power in 1961 and 2014 is the same.
  3. PAR
    PAR Yacht Designer/Builder
    Everyone under rated their outboards, for racing class advantages in the 50's and 60's, SAE standards in the late 70's fixed this issue.
  4. DFAIRCLOTH
    I was looking more for comments on the hull as is was supposedly famous according to old Larson literature.
    Thanks
  5. PAR
    Welcome to the forum.
    Nothing "famous" about those hulls, though the marketing team would be pleased you're still buying into their hype. A pretty conventional, pre 63 series, warped bottom hull form.
  6. Mr Efficiency
    Likes: 1,042, Points: 113, Legacy Rep: 702
    Mr Efficiency Senior Member
    Where are the million bubbles ?
  7. DFAIRCLOTH
    Supossedly the lapstrake hull design created the bubbles and the adds had underwater pictures showing the bubbles flowing under the hull.....Either way it is a cool old boat :)
  8. Mr Efficiency
    I suppose the same could be said for the myriad swaged aluminium boats on the market. I doubt it increases hull speed, what with all the extra surface area created, even if the bubbles "lubricate" the bottom a little.
  9. PAR
    The bubbles actually slow the boat down, not speed it up and all lapstrakes make bubbles. On a technical level, the bubbles decrease the water density locally, which causes the boat to settle a bit, which requires more power to over come. Good marketing hype, that stands the test of time . . .
