| Large Scuppers Does anyone have a link for larger scuppers. Lots of 2" and 3" round ones but I'm looking for something the size of a license plate. Thanks, Stan |
| What is a scupper ? Bulwark door ? Transom drain ? http://www.marineeast.com/a_sch/sch_...d=09&pid=09_06 |
| Hamilton Marine
__________________ David Cockey |
| A scupper I need drains the rear deck either thru the transom or side drain. It has a flap to let water out but does not allow water in. It is to drain a deck if a large volumn of water comes in over the side. Hamilton has nothing on scuppers or drains. |
| http://www.marineeast.com/a_sch/sch_...d=09&pid=09_06 Those are 2 x 6 ...... big scuppers. How much water must you shift ?? For larger scuppers you make them or use scuppers designed for commercial ships. http://www.fraserbronze.com/scupper http://www.lunenburgfoundry.com/Mari...-hardware.html |
Largest is 3" x 9" with a flap.
| Other than scuppers the " waterbox technique" were cockpit water drains from normal size, esthetically pleasing 25mm drains set in cockpit corners...then when the cockpit floods, runs overtop of a sile , floods the waterbox, then drains overboard thru sewer pipe size ports. In my opinion Its cheaper , better looking and more effective |
| thanks for the find at Hamilton marine. That is what I was looking for. When I typed scuppers on their website that did not show up for me. Appreciate the help from all. |
| Yes Michael I too would appreciate a drawing, first i've heard of such a system, ---Tnx. Geo |
| Perhaps I can snap a picture. A stout 12 or so meter twin outboard, alloy salvage workboat, has been recovering a yacht blown onto the beach. She has waterbox style cockpit drains. This style works like a dam. Around the perimeter of this work boats aft cockpit, working deck, is a 150mm or so tall dam. This dam runs the perimeter of the working deck , is capped to keep workman feet from getting wedged and is fitted with drain grates cut into the top cap every meter or so . When a wave washes the aft cockpit, Green water escapes thru the grates, out the topsides, thru half moon openings..scuppers ...cut into the topsides. I didnt notice whether there are baffles in the dam arrangement to resist water blowback |
| recently saw those licence plate scuppers fail on tv, yes there was a failing waterpump pumping the boat full in bad weather but than the scuppers did the rest belive it or not, they were mounted outside in, boat sunk on tv |
| SeaStop Scuppers info | gary1 | Materials | 0 | 10-18-2007 04:33 AM |
| Looking for Venturi Scuppers in Australia | gary1 | Materials | 4 | 05-19-2007 12:28 AM |
| COURSE AU LARGE mag now online | brian eiland | Boat Design | 0 | 12-11-2006 11:33 PM |
| Thinking of large yacht | narulure | Boatbuilding | 5 | 07-20-2005 11:30 PM |
| CE and large roach | Guest | Boat Design | 8 | 10-20-2004 03:24 PM |
