| kite propelled motor boat design Hello, me and a friend are fiddleing with the idea of adding kite propulsion to a motor boat. We came to the conclusion that two characteristics of the boat would be mandatory: - A frontal towing ring where to tie the kite lines and - a rudder maybe .. if motor itself non suitable for turning pourposes. Does it sound like a proper setting ? Where do I eventually find a rudder for a motor boat ? |
| You can either build a rudder or adapt an old one. I assume it is an outboard from what you are saying. It is better to pull it up out of the water. It will cause a lot of drag and turbulence.
__________________ Gonzo |
| It may help to have a look here: get home kite sail New Age Trawler/Motorsailer; Kite assisted PowerYacht Regards Richard |
| ..there is no actual motor boat avilable. it is merely an idea. ..I knew those posts before , but I feel the need of more informations .. I guess I will concentrate on rudder , maybe trying to adapt a sail boat rudder to a motor boat . |
| Would it be possible to use motor at low speed as a rudder ? |
| I've given this a great deal of thought and have conducted some experiments out on the lake. Yes, in broad strokes, it will work and work well; a kite will certainly pull a motorboat along. If you want to move anything other than 45* each side of dead downwind, you will need a keel of some sort. Leeboards would work, but are unsightly and ungainly no matter what Mr Bolger said. An outboard motor will work as a rudder, though poorly. Poorly. So poorly it is very much worth the effort to ship a real rudder of some sort, and of course if it's deep enough you pick up some lateral-plane area. Don't attach the kite to a ring in the bow; someplace just forward of 'midship is much better, especially for reaching or pointing. For downwind work of course it's fine on the bow. Think light; the less weight you have to drag around, the better.
__________________ You make Baby Jesus want to drink Scotch out of the cat bowl |
| schooner design, is it a motor sailor? | ongolo | Boat Design | 11 | 11-10-2007 09:19 PM |
| Looking for a design for a fast, long distance, medium sized, motor boat. | tom_fry24 | Boat Design | 11 | 01-06-2007 10:01 AM |
| self propelled barge | KevinG | Boat Design | 10 | 03-16-2005 11:51 AM |
| Kite Buggy/Boat | upahill_chris | Boat Design | 8 | 10-19-2004 09:35 PM |
| Boat Propelled by Waves Energy | Kneider | Boat Design | 5 | 03-23-2004 05:54 AM |
