Old 03-21-2005, 10:21 AM
James Francis James Francis is offline
Rep: 10 Posts: 21
Kicker Specs
I have a 22 foot center console inboard and I intend to get a kicker for auxiliary power. Does anyone have any experience or input in selecting a specific HP? The boat is a dory style (modified V with a convex/round bottom) and weighs about 4000 pounds fully loaded. I am just unsure if a 9.9 would push it along at a safe speed. I tested a 5 HP and it barely moved the boat.
Any input would be a help.
Thanks,
Jim
Old 03-21-2005, 03:26 PM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
Numbers from Ted Brewer's book
needed horsepower=3 to 4 hp minimum per ton of displacement, 5 hp for ample power. I'd go with a 9.9 hp, yeah. It might be a little fast on full throttle, but it's probably the best option unless you can find an 8 hp, which is certainly available (Mercury makes one) because your boat weighs about 4000 lbs, which is equal to about 1.81 metric tons. 9.9 is more than needed, but should be fine, 8 would be about right, but a little more, if you know how to control it, is probably ok. Remember, though, dory hulls aren't built for speed, despite the fact that it is a deep V (I think...)
Addition: I heard about equation for flat bottom boats, multiply LOA by beam at widest point. Length x Width
(Copied from boaterexam.com, never heard of it)
35 or less
3
36-39
5
40-42
7.5
43-45
10
46-52
15
However, this may not help. Go with the 9.9 unless you can find an 8
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Old 03-22-2005, 09:46 AM
Rep: 10 Posts: 21
Kicker
Thanks very much for the information - I was going to go with a 15hp to have adequate thrust but it sounds like the 9.9 is sufficient.
Jim
Old 03-22-2005, 03:55 PM
Rep: 10 Posts: 857
Alright! Good luck! By the way, did you try the formula? LOA times beam?
Signed-
mackid068
_________
Old 03-23-2005, 11:10 AM
Rep: 10 Posts: 21
kicker
Thanks again, Do you think the the stock prop will work or should I look at a different size and pitch?
Old 03-28-2005, 01:08 PM
Rep: 10 Posts: 857
Sorry for the lateness of my reply. I don't know. Check with your local marine store.
Signed-
mackid068
_________
notebook specs for running CFD codes sasidhar Boat Design 10 07-25-2005 08:31 PM
Meranti ply specs? Phil Locker Materials 16 01-02-2005 07:40 PM
Where can I find sailboat specs? Vince Boat Design 4 06-07-2004 09:37 AM
Kicker bracket for 22' Tuffboat Dave H Boat Design 2 05-25-2004 09:57 AM
AD31B penta specs Powerboats 2 04-01-2003 09:45 PM
