#421
| But you presuppose that the naval architect hasn't actually specified the size and shape of the backing plate ! I'd also be very careful of your definitions here since I can't think of any other term that would describe a shaped inner metal plate that is structurally designed specifically for example to increase the shear area. I'm also very curious as to how anyone could presume to do an FEA analysis or engineering load study without considering the mounted keel and that includes the laminate. I posted before that it's tricky and that it's reasonable to look at modeling it with an isotropic material while matching the E values for the laminate then at least you get the non linear structural response under load.
#422
Not sure if this applies to me, I didn't mention FEA either. For a design of modest ambitions, you might verify a proposed design with FEA but I doubt you design with FEA in hand all along the way. And where would you bound the problem? You'd need to model half the ship to get it right. |
#423
Sorry, I missed that post. Usually several studies are required, large scale to look at the load path from the chainplates through to the keel attachment. Then localised studies to check an adequate FOS for the moment transfer from the keel to the hull.
| Yacht Keels | Ian Rob | Boat Design | 5 | 02-28-2005 05:23 AM |
| Lifting Keels | Danidrac | Boat Design | 0 | 02-06-2005 12:16 PM |
| About keels... | ErikG | Sailboats | 1 | 11-08-2003 01:15 PM |
| keels | stephan shugart | Boat Design | 0 | 01-08-2003 05:10 PM |
| VO 60 an AC keels... | ErikG | Boat Design | 5 | 11-03-2002 10:15 PM |
